I have a video mp4 (avc, aac) file. The voice only comes out of one speaker and the music only comes out of the other. I'm trying to extract and duplicate the audio track so I can get music and voice out of both speakers and then remux the files.
I extracted the video/audio tracks with MyMP4Box Gui, then duplicated, mixed and rendered the tracks in Audacity. I used the FFmpeg plugin with Audacity to import and export .aac. Then I remuxed the files using MyMP4Box Gui. But now the new mp4 has a different length and is out of sync.
One possibly important thing I should mention is that the source mp4 file has a different duration in MPC and only MPC (28 min. 40 sec) compared to all other players. Every other player and video software I've tried -- VLC, KMPlayer, WMP, etc., Mediainfo and all video editors show the same time as each other (26 min 19 sec).
After remuxing all players (including MPC) and video editors show the file as 31 min 33 sec.
Just as a test I demuxed the files and then immediately remuxed them without making any alterations and the file still is 31 min and 33 secs in length and still out of sync.
So what is going on here and how can I fix the file like I want?
	Just to be on the safe side...
 make sure the video stream doesn't have open GOPs, and also make sure you DON'T have an outdated version of MP4Box.exe
 http://forum.doom9.org/showthread.php?t=156110
	Doh I should have compared both files in Mediainfo to begin with. The source file's FPS was 29.970 and the remuxed file's FPS was 25. In MyMP4Box the FPS option was set to "No Change" which I wrongly assumed would match whatever FPS the source file was. I changed it to 29.970 and now the file is the right duration and synced.
 Thanks.
 What are open GOPs and how do you check for them?Originally Posted by El Heggunte
  Recoding/Remuxing a HD mp4 Video FileBy 360 in forum Newbie / General discussionsReplies: 8Last Post: 30th Oct 2011, 01:20
  captured audio and video are desyncedBy muffinman123 in forum Capturing and VCRReplies: 1Last Post: 5th Sep 2011, 09:03
  mp4 video not playing for the full length in vlc playerBy sumeshkri in forum Newbie / General discussionsReplies: 2Last Post: 11th Oct 2010, 18:50
  Win32 FFMpeg Makes Invalid MP4 ?By Endemoniada in forum Video ConversionReplies: 2Last Post: 22nd Sep 2010, 10:32
  .TS to .MP4 what makes this so difficult?By pinehyq in forum DVB / IPTVReplies: 2Last Post: 30th Aug 2009, 18:56
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
