Hey all,
I am trying to cut a specific section from a home movie but I'm having problems. I know the start and end time I want but when I set Handbrake to use those times the result is not what I asked for, but starts slightly ahead. If I try one or two seconds earlier it is the exact same, but if It try several second earlier it jumps several seconds backwards. I cannot get it to start at the point I want (in between the two it gives me). I have tried Format Factory with the same result.
Would this be a problem with the specific video file, or is it a common problem? Is there a workaround?
What is the video source?
It might be that you must cut at keyframes with those applications. -
It sounds like you are running in lossless mode which only allows cuts on keyframes. If you want frame accurate cuts you need to reencode -- at least the cut GOPs. Try using VirtualDub. It has a smart editing feature which will only re-encode cut GOPs.
We really do need a "like" button. Yes, Virtualdub in smart render mode.
Can't Seek Specific Time In WMV Video
By imdaman in forum EditingReplies: 9Last Post: 8th Jan 2013, 11:48 -
screenshot of mov file at specific time
By ecos in forum Newbie / General discussionsReplies: 4Last Post: 9th Mar 2012, 03:18 -
How to cut mkv files at specific frame
By Pitorasilo in forum Newbie / General discussionsReplies: 1Last Post: 5th Sep 2011, 12:10 -
Will this cut my processing time in half?
By jsbenson in forum ComputerReplies: 7Last Post: 17th Oct 2009, 21:45 -
Specific Problem
By jakob91 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 29th Jul 2009, 10:36
