Results 1 to 10 of 10
  1. Hello. I usually Google my problems and try to fix them but nothing i have tried seemed to work. The problem is that i get these weird artifacts that seem to appear in dark areas of videos. i tried using different video players tried different codec packs i re installed my display driver i checked different videos but they still seem to appear i tried using a HDD plugged into my tv and playing the same file and it looks great and also on my galaxy s3 and it looks great but when i use my laptop it happens i even tried plugging it to my tv with an hdmi its look really bad like these block like and vertical line artifacts.
    i appreciate any help i am honestly stumped
    i added some samples.
    • Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1
    • Processor: Intel(R) Core(TM) i7-2860QM CPU @ 2.50GHz (8 CPUs), ~2.5GHz
    • Memory: 6144MB RAM
    • NVIDIA GeForce GT 555M
    Video simply do not compress well when dark. H.264 or MPEG-2.
    I have this is many commercial DVDs, and those are often using very high-grade hardware.
    Aside from using more bitrate, not much can be done.
    Also make sure the TV/monitor isn't turned too bright.
  3. I'm a Super Moderator johns0's Avatar
    canada
    Downloaded tv rips usually have low bitrates so there's nothing you can do unless you buy the retail version.
  4. Banned
    New York, US
    And the source of the Videos was....?
    And they were created with.......?
    And they had intermediate processing using....?
    And the final output format/encodee is.....?
    The most common issue is someone turning to brightness too high.
    That needed to be repeated.
  6. Originally Posted by johns0 View Post
    i understand that but it just seems much more noticeable on my laptop compared to my other devices. is there something i can do to make less visible other than brightness.
  7. putting the brightness on low doesn't seem to make a big difference i guess i just have to deal with it but what i dont understand is in a different laptop or my tv using a HDD the artifacts are there but much much less noticeable compared to my laptop even when the laptop is connected to the tv with an hdmi vs hdd is much different. i added the mediainfo for the 2 files in the screenshot.
    File 1
    Format : Matroska
    Format version : Version 2
    File size : 206 MiB
    Duration : 24mn 10s
    Overall bit rate : 1 193 Kbps
    Encoded date : UTC 2012-02-26 03:55:53
    Writing application : mkvmerge v4.1.1 ('Bouncin' Back') built on Jul 3 2010 22:54:08
    Writing library : libebml v1.0.0 + libmatroska v1.0.0
    Attachment : Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes
    Video
    Format : AVC
    Format profile : High 10@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 8 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 24mn 10s
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 10 bits
    Scan type : Progressive
    Writing library : x264 core 118 r2085+614 d1cc25d
    Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / fade_compensate=0.00 / psy_rd=0.60:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=infinite / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=19.1 / qcomp=0.60 / qpmin=10 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / aq=2:1.00
    Language : English
    Default : Yes
    Forced : No
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 24mn 10s
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Compression mode : Lossy
    Default : Yes
    Forced : Yes
    Text
    Format : ASS
    Codec ID : S_TEXT/ASS
    Codec ID/Info : Advanced Sub Station Alpha
    Compression mode : Lossless
    Default : Yes
    Forced : No
    File 2
    Format : Matroska
    File size : 958 MiB
    Duration : 46mn 25s
    Overall bit rate : 2 886 Kbps
    Encoded date : UTC 2013-04-09 11:12:52
    Writing application : mkvmerge v2.9.5 ('Tu es le seul') built on Jun 17 2009 16:28:30
    Writing library : libebml v0.7.8 + libmatroska v0.8.1
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, ReFrames : 5 frames
    Duration : 46mn 25s
    Bit rate : 2 444 Kbps
    Height : 720 pixels
    Frame rate : 25.000 fps
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.106
    Stream size : 812 MiB (85%)
    Writing library : x264 core 130 r2273 b3065e6
    Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Default : Yes
    Forced : No
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : A_AC3
    Duration : 46mn 25s
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 128 MiB (13%)
    Language : English
    Default : Yes
    Forced : No
  8. DECEASED
    Jun 2009
    Heaven
    [ nevermind ]
    Last edited by El Heggunte; 18th Aug 2013 at 17:27. Reason: I had misunderstood the OP's problem : - /
  9. Which media player are you using? Try changing the setting of your video card for displaying video to see if that helps. If when using your laptop, video appears to have less contrast or looks "washed out", it could be a levels issue. As PCs and "normal video" (and TVs) use a slightly different range of levels, even when connecting a PC to a TV you need to ensure they match. My TV has a setting to change the input level, but not all do.
    Nvidia Control Panel (I'm using XP if it makes a a difference):
    PS. If the laptop's using the Intel graphics then the above Nvidia thing won't help anyway. I don't really know how laptops with both Intel and third party video work.
  10. Your videos are over compressed and the black level on your monitor or graphics card is too high.
