  1. Hi Guys
    dont know if this is in the correct section
    recorded some films with my vu+solo2 linux satellite receiver
    FTP them to my computer and converted them to MP4 Hd
    just brought a blu ray burner for my computer
    and decided to burn a film to blu ray
    burnt fine using Power2go 7
    but does not auto start in my computer or home surround
    what am i doing wrong ??
    1 . is it the wrong format they are converted to ?
    2 . wrong software being used ?
    or other problem i have missed
    anybody got a set up i can use for converting films
    so i can burn them to blu ray ?
  2. Member DB83's Avatar
    Jul 2007
    Is Power2go 7 a blu ray authoring program ? I guess not and you have just created a data disk - simply burning your video to the disk without the associated files for blu ray.
    You can use MultiAVCHD to create the neccessary folders & files and imgburn to burn those folders to a blank disk.
  3. yes it came up as a data disc
    it plays on my computer and surround
    but you have to tell it to play
    so power2go is no good for burn blu rays
  4. so is there not an all in one blu ray burning software that i can get
    to do the task ?
  5. Member DB83's Avatar
    Jul 2007
    Your drive probably came with the Cyberlink suite of which Power2go is one element. I think that just burns disks. There is a difference between 'authoring' which creates the files and 'burning' which puts the created files on to the disk although many authoring programs also make a fist of burning.
    That suite may also have a program called Power Director and that can author/burn dvds but I do not know if it also author/burn blu ray. Other than that you can buy blu ray authoring programs - check the tools section - or use the software I have suggested which will cost you zilch except a little learning.
  6. yes
    been looking at power producer 6
    the drive comes with 5
    and does not do blu ray
    downloaded a trial of the 6 ,but it only burns 30mins
    thanks for the info
