Results 1 to 11 of 11
    Aug 2013
    indonesia
    Hello all..
    im new in useing TMPGenc authoring Work 4
    please someone help me about making karaoke video with L/R audio.
    i have .DAT .Vob or windows media files all with L/R sound
    want to create my own dvd karaoke.
    in the clip properties i start with billingual and run stimulation, it works. and have L/R sound. and to make it more convince i run export output and really ok in my PC im happy. but when i burn it, theres no L/R sound it mixed. i cant turn off the voice
    then i change starting with multiaudio
    i run stimulation everythings work fine.
    but when i burn into dvd.
    the L/R audio mixed again..
    so i start spliting the audio with sound forge into mp3 The sound and the voice
    and go to clip propertiest multi audio with a different source
    source 1 sound, source 2 voice.
    run stimulation again works fine.
    burn it again and got no L/R sound. only sound without voice.
    anyone can help me ? i hope i can get the solution as soon as possible.
    - sorry my english pretty bad.
    Thank you
    Aug 2013
    indonesia
    the problem is i cant switch the video audio from remote...
    i must back to title menu switch the audio from audio menu..
    please ?
  3. Member Cornucopia's Avatar
    DVD Karaoke works differently than VCD Karaoke. Usually with DVDs, the audios (Music, Voice, Music+Voice) are on separate streams. VCD only has the one audio stream (with 2 channels - L + R).
    To convert, demux your VCD (.MPG or .DAT) file, decode it to .WAV and put it in an audio editor (e.g. Audacity). Split the channels into 2 separate mono tracks.
    Depending on you source, you may have M (L) + M+V (R), or maybe M (L) + V (R), or something similar. Assuming the original mastering engineers didn't rebalance the respective tracks, a simple equal-level mixing in-phase or out-of-phase will get you a third track. For example, (M) + (V) = (M+V). (M) - (M-V) = (V), etc.
    Making sure you sample-rate-convert to 48kHz (for DVD standard), you just re-encode to mp2/ac3 or leave it LPCM wav and add the separate streams to your dvd in your authoring app, choosing the order based on your own priorities.
    Aug 2013
    indonesia
    hi Thx for your replay.
    but in TMPGenc i already split it.. video, L and R
    Aug 2013
    indonesia
    and i tried another way..
    the problem is in the "audio menu"
    i have to off or on the voice through title menu...
    i want it from dvd remote L/R audio.
    need help.
    Thx
    Aug 2013
    indonesia
    hello any help here?
  7. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    You are not listening. Read this again:
    https://forum.videohelp.com/threads/358178-Burning-Audio-L-R?p=2260994&viewfull=1#post2260994
    Aug 2013
    indonesia
    im new.
    i just splitting the stereo track to mono in audacity
    export the file to ac3
    what next ?
  9. Member Cornucopia's Avatar
    REAUTHOR. From scratch.
    Aug 2013
    indonesia
    Thx for the respond..
    "reauthor from scratch"
    what author ? find nothing except cat there =.=
  11. Member Cornucopia's Avatar
    Look it up. Act like you are authoring a brand new dvd using your own original materials and legit "authoring" software. Sheesh, I'm gonna just put this one down to language barrier.
