.How about media Compatibility of Portable Devices such as PSP, PS3, Xbox. ?.
What are the things that directly and mostly affect the compatibility?..
about below things,
- Max. Reference Frames
- Max. B Frames
- Max Resolution
- AVC Level
- HE AAC
- SRT
Especially I want to know about Reference Frame Limit!..
As I know PSP Support AVC Level Main @ 3.0.
PS3 and Xbox support AVC Level High @ 4.0.
Regarding ReFrames, All support ReFrames Upto 3.
But can we use more than 3 re-frames, with any setting?..
how?
With regarding device playback, does max re-frames supported depends on avc level or resolution?
Also does they support HE SBR AAC and HEv2 SBR+PS AAC audio?.... and SRT subtitles?
Most likely not. 3 would break most settop players so far as I know. Profile 4 is 3 referrance frames and that is what most bluray players are. (edit - I meant MORE than 3 would probably break a player)Originally Posted by kotuwa
I think your best bet is to forget a minimum profile and do one of two things -
1 - stream to dlna compliant devices and use your computer to transcode on the fly to the given device (playon or tversity for example)
2 - get a settop media player like the wdtv media player.
Option 2 is your best bet. It will reduce your need to convert. The best media players will play virtually any file type you throw at it - though I don't know about 10bit h264, you'd have to research a particular unit to be sure it handles 10bit h264.
But a settop media player is by far the most hassle free option you have. And you can get used ones at a good price at online auction websites.
Just be careful of roku type devices. They don't have very flexible playback ability (codec support that is)Last edited by yoda313; 17th Aug 2013 at 22:04.
Xvid, Max B-frames for PS3 & Xbox 360
By duff916 in forum Blu-ray RippingReplies: 3Last Post: 15th Jan 2012, 21:13 -
Alternatives to AAC on mp4 for PS3
By dvazriel in forum DVD RippingReplies: 0Last Post: 11th Apr 2010, 13:52 -
compatibility of poineer xv-htd540 with ps3 and xbox 360
By j.dublu in forum Media Center PC / MediaCentersReplies: 1Last Post: 21st Feb 2009, 03:38 -
PS3 AVCHD, Ref Frame 8+Level 5.1+B-Pyramid...????
By NiGHTsC in forum Video ConversionReplies: 1Last Post: 29th Dec 2008, 19:45 -
PSP Video Converter with good volume level?
By akumaryu in forum Video ConversionReplies: 6Last Post: 2nd Sep 2008, 21:40
