i tried using ffmpeg to download http://www.youtube.com/watch?v=OVzt2rsfMc0
I get a HTTP error 403 ForbiddenCode:ffmpeg -i "http://www.youtube.com/api/manifest/hls_playlist/id/395ceddabb1f31cd/itag/94/source/youtube/ratebypass/yes/pfa/1/pbr/yes/hls_chunk_host/www.youtube.com/gir/yes/clen/1273957616/lmt/1347681614309149/pmbypass/yes/playlist_type/DVR/cp/U0hWS1dOVl9KUkNONl9PSFpGOk9FVFhYNVdMS1g2/maudio/1/fexp/916603,920505,913560,937202,916623,936204,902522,909546,906397,929117,929121,929906,929907,929922,929127,929129,929131,929930,925720,925722,925718,925714,929917,929919,929933,912521,932306,913428,937003,904830,919373,930803,904122,938701,911423,909549,900816,912711,935802,904494,906001/sver/3/upn/6DCCVUJDi_0/cpn/7a5fXI57jOydfsjt/ip/68.145.181.34/ipbits/8/expire/1376738558/sparams/ip,ipbits,expire,id,itag,source,ratebypass,pfa,pbr,hls_chunk_host,gir,clen,lmt,pmbypass,playlist_type,cp,maudio/signature/3EE08809BABFE81CF066464F5E6659F51AF84D6E.8D8D4802A47087AF63AB1FD0DF6FB003A9CD4433/key/dg_yt0/file/index.m3u8" olympics.flv
Unable to open key file
Error when loading first segment
Invalid data found when processing unit
All links work in my browser.
Any idea what this is and any workarounds to this?
I've read on other threads that youtube had a 403 error with realplayer downloading. And this seemed to work at some point, but it's not working for me now.
That's weird. It should work in your browser. But you would think they would say you are not in an available locale rather than just slap you with a 403 error if it was that. I think it might have something to do with cookies. But i don't know how to use cookies with ffmpeg yet. Did you have cookies enabled when you viewed it?
On further investigation it seems the url that i'm getting the 403 error is a key for encryption
#EXT-X-KEY:METHOD=AES-128
You have to paste it in url to get 403. If you click on link you get some funny characters.
But i can view the video through my browser. I also tried using cookies with ffmpeg but not luck. Is there a way to get past this?Last edited by raz3; 19th Aug 2013 at 09:33.
Yes, I have the same problem. Does anyone could find a solution? It would be great.
Many thanks! -
Tried hls-fetch, and it didn't work. Tried it on a stream that works with ffmpeg. Doesn't even work. And aes-cbc in openssl gives an error with hls-fetch. Tried to decrypt with other modes, but i don't know if it worked because hls-fetch doesn't join the files properly to find out. So it just plain does not work.
How to record part of live stream m3u8(30min)& save it as mp4 using ffmpeg?
By spiderMan007 in forum Video Streaming DownloadingReplies: 0Last Post: 18th Mar 2013, 18:54 -
new ffmpeg - my BATs doesn't work anymore - HELP! [SOLVED]
By CactusMan in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2012, 14:24 -
youtube doesn't like joined .MP4 h.264 files
By Driber in forum Newbie / General discussionsReplies: 4Last Post: 29th Jun 2012, 12:21 -
ffmpeg doesn't work at all
By Paulo2009 in forum ffmpegX general discussionReplies: 27Last Post: 5th Aug 2009, 00:55 -
convert avi to dvd with ffmpeg doesn't work-why?
By lilly333 in forum ffmpegX general discussionReplies: 21Last Post: 18th Mar 2009, 17:00
