I have done a few encoding of animes that are originally 10bit to 8bit using Vidcoder with default high settings (H264, same fps as source, high profile lvl 4.2, rc-lookahead=50:ref=4:b-adapt=2, crf=16 and default video filters). Now, the results are not very satisfying because the video drastically deteriorates its quality.
I was thinking it has something to do with the video filters(detelecine, decomb, deblock, etc) settings that I haven't played with. I tried to research more into this but couldn't find an easy to understand wiki/guide.
Any suggestions on what I need to do? Any sources that are very to understand about video filters when using vidcoder?
1. What's the source? I know you said 10 bit, but is it from DVD or HD?
2. What is the target device for the video?
3. Are you resizing the video?
4. What reduction in quality are you seeing? Banding? Just general degradation?
I'm guessing you have downloaded some modern anime, chances are it isn't interlaced so you won't need detelecine or decomb. If it's high quality you shouldn't need deblock either. If I'm right about your source and you're using vidcoder, disable all the filters.
Leave this: rc-lookahead=50:ref=4:b-adapt=2 alone.
CRF16-18, High@4.1, tune=animation, preset=very slow should give you the best possible results.
If you are resizing, you may have need of filters.Last edited by blud7; 17th Aug 2013 at 08:51.
1. Yes mostly HD (1080p/720p) and a few 480p older animes
2. Ps3 using showtime. Only 8bit video & strictly follows http://en.wikipedia.org/wiki/H.264/MPEG-4_AVC#Levels
3. No resize. Same as source.
4. It's mostly general degradation. My fault, actually I used CRF 22 instead of 16 as posted above. After using CRF 16 plus the settings you mentioned, the 8bit video is pretty much the same as 10bit. No noticeable difference. I guess the very slow preset + CRF = 16 fixed it.
How about for older animes which aren't modern? Any thoughts on what usually needs to be set on filters?
Thanks much!! -
Vidcoder doesn't have much filters. Since your video I'm assuming is progressive (not interlaced) just leave it.
You can use a denoise filter, but then again Vidcoder's is rudimentary and destructive.
And if there isn't much noise, which is generally the case with anime, don't bother.
Basically, if you're just transcoding from one format to another, don't worry too much about filters.
If you want to enhance your old videos, that's another story and not a job for Vidcoder.
I'll just add that x264 has an internal deblock filter which is adjusted by tune=animation.
I'm not sure if Vidcoder's deblock filter is the same, it may not be.
(If your older videos have issues, they need to be treated with specifically, eg combing, colour washing etc. and you'd need to provide screenshots / what you wanna do.)
How to removed parts from 10bit mkv videos?
By Choey in forum EditingReplies: 5Last Post: 28th Jul 2013, 01:14 -
Convert 10bit MKV videos in to 8bit MKV with XMedia
By RaW D Coy in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2012, 13:10 -
MKV 8bit to 10bit subtitle help!
By lolek31 in forum SubtitleReplies: 8Last Post: 8th Jul 2012, 22:26 -
How to encode anime to 10bit x264?
By Deadly9000 in forum Video ConversionReplies: 45Last Post: 12th Mar 2012, 10:10 -
Converting from H.264 8bit to Hi10
By john157 in forum Newbie / General discussionsReplies: 3Last Post: 7th Aug 2011, 09:51
