Results 1 to 9 of 9
  1. Hi. I would appreciate any help with downloading this
    http://player.ntr.nl/nsj/?id=2013_video_gary_clark_jr
    and any other video from here
    http://www.radio6.nl/nsj13_concerten.html
    After two hours of trying a bunch of programs with my son "assisting" all I managed to get was more then a 1000 ts files (each about 7 sec long with IDM), but I would prefer one file in any format.
    Thanks for your help!
  2. hi
    i'm not sure but i think you need to use ISM Downloader
    http://md5decrypt.altervista.org/ismdownloaderavc1.htm
  3. i see chap already help you in other thread
  4. ISM Downloader is not working....thanks anyway
  5. ffmpeg will do it
    ffmpeg -i "http://l24m43a3d6a1ba00520f06e2000000.e3aa7b4bd940b369.adaptive-e99c1a.npostreaming.nl/lmshieldv2/o/ntr/nsj/2013_video_gary_clark_jr.ism/2013_video_gary_clark_jr-audio_eng%3D127967-video_eng%3D902000.m3u8" jazz.ts
    To get the m3u8 link in firefox go to menu > web developer > web console
    Filter out m3u8
    Play the video and many m3u8 will appear.
    Download the first one that appears and open with notepad2 to view which links provide each resolution.
  6. to raz3, thanks so much....unfortunately we are either too stupid or impatient.....can't get it to work myself and my son will kill me soon.
    Any chance you get the show and upload it somewhere (Mega, Mediafire etc)? Thanks
  7. Try this first.
    Assuming you're on windows.
    download from http://ffmpeg.zeranoe.com/builds/
    use 7-zip http://www.7-zip.org/ to open it
    Extract the contents to a folder.
    Open folder and direct yourself to folder "bin", and you will see three .exe files. One of the files is ffmpeg
    Hold down windows key and press R. A Run window will pop up. Alternatively you can click on start and type in cmd in the search field.
    Type in cmd. A command window will pop up
    Type in cd c:\users\name\desktop\nameoffolder or whatever path you've saved ffmpeg to. the "bin" folder
    Now type in the command above. Make sure your firewall settings allow you to connect with ffmpeg.
  8. I got the shows...thanks a lot for everybody's input.....great place here
