i just converted a divx srendipity of realli high quality into and mpg file using tmpgenc and the thing is that it turns out to be only 870 megs, i find this really strange, aren't vcds usually around 1.4 gigs total for 2 cds? is there a way to set tmpgenc to make the mpg as high quality possible using as much space it can for a 2 cd vcd?
I think you made a VCD. And then 850 Mb can be normal if the film is around 90 minutes. If you make an SVCD it wil be larger...
Technique potential is great
By zoobie in forum Newbie / General discussionsReplies: 2Last Post: 9th Dec 2011, 21:25 -
Thoughts or recommendations on my potential build
By lordhutt in forum ComputerReplies: 16Last Post: 2nd Nov 2010, 17:45 -
Potential 'WaitImmediateIO' Deferred Error in ImgBurn
By cd090580 in forum Newbie / General discussionsReplies: 3Last Post: 25th Sep 2008, 12:09 -
Audio Delay and other potential A/V sync Issues?
By rkr1958 in forum AudioReplies: 1Last Post: 2nd Dec 2007, 14:33
