Hello all,
i could not find the home cinema HT-F9750 in the hack list so i was wondering if by any chance someone here could help unlocking this home cinema for blu rays.
Thx a lot
A snowball's chance in hell of finding a hack for a home theater system.....and there are only 5-10 hackable Blu ray players.....IF THAT.
This is exactly the same as the HT-E6750W.
1. Ensure there is no disc in the drive
2. Power off using remote
3. Power on using remote
4. No disc is displayed on the front of the player
5. Highlight the 'Settings' Option on the Main screen (Not the default 'Smart Hub' option)
6. Press the BD button on remote (left hand top corner, under the RED on/off button)
7. Without hurrying type in [REPEAT] 7 6 8 8 4
8. Your current region is displayed (very briefly) in the top right hand corner of the screen (Mine was 4)
9. While you see the current number highlighted, Press 9 on your remote (making it region free)
10. Power off using remote
11. Power on using remote and test
Hopefully this will help you out, good luck! -
Samsung BD-P1600 - Region Free Unlock code
By kennyt in forum Blu-ray RippingReplies: 43Last Post: 17th Apr 2024, 17:54 -
Samsung BD-D5300 Region Free/Unlock Help needed!
By Sovoth in forum DVD & Blu-ray PlayersReplies: 8Last Post: 27th Jul 2013, 17:34 -
Samsung Dvd-E360k Region 4 to Free/Unlock Help needed!
By luhh in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Jul 2013, 12:52 -
Samsung Smart Blu-Ray 3-D Player - Model BD-D5800 Region Unlock/Hack
By VoYD666 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 24th Oct 2012, 05:49 -
unlock region code Samsung DVD-VR357?
By amyfj in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st May 2011, 08:19
