I'm trying to extract the subtitles and fonts from one mkv file, and the video and audio streams from another mkv file, and merge them together. I'm using mkvtoolnix-unicode-6.3.0-1 and MKVExtractGUI-2.2.2.9 to extracts the video, audio or subtitle streams without problems. However, the font files never appear in the output directory.
I'm checking the boxes next to the font files but they're simply not being extracted. Any ideas as to why this this isn't working and what I can do to solve the problem?
Thanks for any advice you can offer.
You can try the mkvcleaver , or original mkvextract
Another method instead of extracting , is to merge the video & audio into the mkv file with the subs , uncheckmark the original audio & video using mkvtoolnix -
mkvcleaver works great and extracts the fonts without problems. Thanks a lot for the help.
There must be some sort of bug in MKVExtractGUI that's preventing it from extracting fonts. -
MKVExtractGUI-2 hasn't been updated in a while, unfortunately, and it's had issues with more recent versions of mkvtoolnix before, so I wouldn't be surprised if that was the case, now.
MKVExtractGUI-2 vs MKVToolnix
By jandor2009 in forum Video ConversionReplies: 7Last Post: 6th Jan 2012, 19:06 -
Using MKVExtractGUI-2 batch tool
By CasanovaFly in forum Video ConversionReplies: 4Last Post: 2nd Jan 2011, 10:05 -
Having Problems with MKVextractGUI
By PlissandrO in forum SubtitleReplies: 2Last Post: 30th Sep 2009, 04:50 -
Quick question about mkvextractgui
By draco_nite in forum Video ConversionReplies: 9Last Post: 7th Aug 2009, 18:41 -
mkvextractgui with AVC problem
By Szymus in forum Video ConversionReplies: 2Last Post: 2nd Feb 2009, 13:36
