Hey guys,
Just wondering if there are any video converters out there that allow you to convert multiple video files into the same number of files... if that makes any sense. Basically this:
Video_File1.mkv
Video_File2.mkv
Video_File3.mkv
.. etc.
After conversion:
Video_File1.avi
Video_File2.avi
Video_File3.avi
.. etc.
I currently use AVS and can only convert and merge multiple files into one big file. I can also convert using batch mode, though to be honest I don't know what that means.
The batch mode in avs should be able to do that. But I don't use avs so I'm not sure how...
Or try freemake video converter, xmedia recode, winff, tencoder. All free.
ripping multiple episodes from dvd into separate files
By arattan in forum DVD RippingReplies: 7Last Post: 5th Aug 2013, 08:18 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
Converting and placing multiple files on a DVD
By -phenom- in forum Newbie / General discussionsReplies: 2Last Post: 8th Aug 2010, 14:27 -
Creating a DVD Menu for multiple divx files without converting them
By LGT in forum Newbie / General discussionsReplies: 23Last Post: 21st Jul 2010, 14:04 -
Converting multiple AVI/mpeg files and 'chapterising' them
By warren218 in forum Video ConversionReplies: 7Last Post: 18th Feb 2009, 09:24
