I'm planning to start a let's play channel on YouTube. I have tried to record using my Dazzle Video Creator Platinum HD on Pinnacle Studio 15, but I ran into some problems with the video and audio de-syncing. First, I did a few test recordings and discovered that the quality was set too high. I turned it down to 80% quality and it ran just fine. Then I tried recording using commentary which I recorded on a progam called Audacity. Once I did this, the video and audio once again had de-syncing problems. I do not know how to fix this, and I would like to record with live commentary if possible. If anyone has the solution to this problem, please respond to this post. If you need any additional information, please ask and I might be able to give it to you. Thank you
Results 1 to 1 of 1
[Sony Vegas Movie Studio Platinum 12] Replacing video selection with JPG?
By yetanotherlogin in forum EditingReplies: 4Last Post: 23rd Dec 2012, 18:54 -
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 03:03 -
Dazzle Video Creator Plus Help Please!
By FragpooL in forum Capturing and VCRReplies: 1Last Post: 23rd Jun 2011, 23:51 -
Video Artefact Problem - Sony vegas Movie Studio Platinum 9
By abeelandig in forum Video ConversionReplies: 5Last Post: 11th Jun 2011, 10:40 -
Problems Capturing HDV into Pinnacle Studio 11+
By lasereyes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Mar 2009, 08:58
