Results 1 to 9 of 9
The normal process on Unix/Linux derivatives is to simply go into the source code directory and do something like this on the command line:
./configure.sh
make
make test (or maybe maybe check - there may or may not be any tests though)
make install
I admit to never building on Macs so maybe there's some reason this won't work that I don't know about. -
sadly this is not helpful to me at all, since you would still be missing tons of dependencies.
(also simply calling configure normally doesn't build a static version) -
https://github.com/videogorillas/videoscripts/blob/master/build-ffmpeg-mplayer.sh looks interesting.
(if I get this working I would still have to add libbluray to make the whole thing useful for me, frist I'm trying to get the whole thing working)
changes so far:
- removed "/Developer" everywhere, since xcodebuild is located under /usr/bin on my system
- changed zlib version from 1.2.7 to 1.2.8
- changed yasm version from 1.1.0 to 1.2.0
Any chance you might be able to build ffmpeg with the updated x265 encoder or is that beyond your capabilities? It doesn't look like we're going to get stdin any time soon to be able to use it in software like your program or Virtualdub. There is a patched ffmpeg with an x265 encoder but it's over a year old and built on hm7 so it's pretty useless. An ffmpeg patched with vp9 would also be a good thing. Not sure why ffmpeg doesn't have vp9 support now.
sorry, but I really have zero interest in x265 atm. and adjusting the hm7 to a hm10 patch is probably not really interesting.
For vp9 encoding I normally use vpxenc.
No one cared, since vp9 is too slow atm.Not sure why ffmpeg doesn't have vp9 support now.
Yeah, I forgot about the new vpxenc.exe file I downloaded with vp9 support. I was wrapped up with the x265 encoder the last couple of weeks. I need to get back to figuring that encoder out. They're both way too slow right now for everyday use. I'm just interested in getting whatever CLI encoders working in Virtualdub that I can.
I wished the x265 encoder was faster because the quality of a 1080p file is incredible for the small file size. .55 to 1 fps is just way to slow to encode with on my machine. Eventually they'll get both encoders optimized and maybe by then I'll be able to afford to build a new PC. Right now, x264 is still the only way to go IMO and will probably be for at least two or three more years. It took a while before x264 took the place of DivX/XviD. -
Attached the current version of the build script which should only require Xcode to be installed. (Tested in a VM running Mountain Lion)
It creates it's own ram disk, where all the file handling takes place, at the end a .dmg file is created inside the 'Downloads'-folder.
-> damn, script fails while trying to build libbluray :/
(http://jsdelfino.blogspot.de/2012/08/autoconf-and-automake-on-mac-os-x.html should fix this)Last edited by Selur; 24th Aug 2013 at 07:42.
found some ffmpeg static builds over at: http://www.evermeet.cx/ffmpeg/
ffmpeg / H264 (need help to build an optimized command line)
By iwiiiiiiiiii in forum Video ConversionReplies: 13Last Post: 22nd Oct 2011, 10:41 -
FFmpeg Win64 static trunk build with libfaac request
By astrosyn in forum Video ConversionReplies: 0Last Post: 14th Jan 2011, 16:37 -
I need a supported build of ffmpeg for Avanti 0.4.8
By flashandpan007 in forum Video ConversionReplies: 1Last Post: 23rd Jun 2010, 09:28 -
Which ffmpeg build plays xvid in virtualdub after encode? ... [RESOLVED]
By vhelp in forum Software PlayingReplies: 1Last Post: 4th Sep 2009, 22:04 -
Video Capture with Mplayer, Mencoder or ffmpeg under Winxp. Is it possible?
By gll99 in forum Capturing and VCRReplies: 0Last Post: 11th Sep 2008, 18:00
