I am about to install and setup BDRebuilder.
I understand that I also have to install Haali Media Splitter and avisynth to link with BDRebuilder for it to work.
Should I install HMS and avisynth before or after BDR? Are there any setup things that I need to do within BDR, HMS and avisynth to insure that the three programs work correctly with each other?
Am I correct in understanding that BDR should burn in mp4 mode if I want to playback the BD copies in non PC stand-alone Blu-Ray players?
I have a subscription to AnyDVD HD.
Thank you!
Install haali, avisynth first and then try http://www.jdobbs.net/freeware/inspect.exe to see that everything is correct.
If you want to play discs in a stand alone blu ray player, you can use BD Rebuilder to output to blu ray format. If your stand alone player has support for mkv, mp4. or AVCHD, you could use those formats instead. But you won't have menus in mp4 or mkv files if that is important.
Ripping with BDRebuilder
By tarzan54 in forum Blu-ray RippingReplies: 7Last Post: 26th Jun 2012, 20:58 -
Problem with BDrebuilder
By tarzan54 in forum Blu-ray RippingReplies: 10Last Post: 20th Jan 2012, 19:45 -
BDrebuilder stops halfway, help please
By volam1 in forum Blu-ray RippingReplies: 16Last Post: 24th Oct 2011, 18:41 -
PowerDVD 7.3 and new BDRebuilder
By dharper40 in forum Blu-ray RippingReplies: 4Last Post: 7th Sep 2011, 07:23 -
BDrebuilder
By durkinjt in forum Blu-ray RippingReplies: 3Last Post: 11th Dec 2009, 21:58
