Hi there,
it's a newbie here..
I need to convert batch some mov files taken with an iPhone 4s to a format which let me save some space and quality of the video.
Any advice? I've tried both Handbreak and Winx Video converter for Mac but they don't recognize the portrait orientation of the video and gives me back a video in landscape...![]()
hopefully you can suggest something for a Mac and batch...otherwise also Win and not batch will work!
Thanks a lot for your patience and help!
Dario
iFFmpeg might be worth buying. Be sure to try trial first.
You could also try mpeg streamclip, but no batch support.Last edited by Baldrick; 14th Aug 2013 at 05:06.
Thanks!
The second works and has got also a rotation feature even if it's not batch...it's great!
Ciao!
Dario
Split/Trim/Join MOV files (works great with Canon SX130's files)
By truchopol in forum EditingReplies: 3Last Post: 27th Jul 2012, 10:35 -
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 11:22 -
Mov conversion help?
By Timbo78 in forum Video ConversionReplies: 2Last Post: 13th Sep 2010, 06:10 -
removing background noise in AVI files created from .MOV files
By p_s_92 in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jun 2010, 08:26 -
Canon 7D MOV 1080p files problem getting quality H264 conversion
By lostinvideo in forum Video ConversionReplies: 3Last Post: 11th Nov 2009, 10:16
