I have windows 7 64 bit with 2 9500 GT graphic cards with 32 cores.
Looking for a ripper that will take the processing off my CPU and use my cuda core. Wish I hand a i7 that uses integrated graphics I saw this clip on youtube and some guy had the encoding going x4 using the i7 IG (integrated graphics). But all I have is a x6 AMD core. Any all in all looking for the fastest ripper on the market free or not.
I'm assuming you are commenting about encoding/conversion? Ripping is just exact copying the disc to your HDD. I have a six core AMD OC'd to 3.6Ghz with integrated graphics. It takes about 20 minutes average to encode/convert a DVD disc to a MKV with great quality at about 2GB size. This is with VidCoder/Handbrake. That's fast enough for me.
Using CUDA, you may get a faster encode to some formats, but the quality may suffer a bit.
You didn't mention what format you are converting to or what program you use for this and what quality you want? -
Thank you for that clarification, ripping straight to a DVD-5 and quality is not that impotant just enough to fill the whole disc not to waste any space on the blank disc.
So the main featers is speed speed speed thank a lot for your replay
Also if I get a faster graphics card with more cuda cores will that speed up my encoding ...Last edited by AndreL; 13th Aug 2013 at 20:05.
More CUDA cores would definitely encode faster. Encoding a 44 minute HD video using CUDA on my 8600GTS with 32 CUDA cores took 1:34:22, but my GeForce GTX 550 Ti (Fermi) with 192 CUDA cores did it in 22:44. This was even faster than my Intel i7 3770k using Quick Sync which took 25:15. Using x264 (2-pass) software encoding took 2:11:05 on the same video. I also found out since then that x264 encoding even using 1-pass encoding can provide superior video quality than both CUDA or Quick Sync at far lower bitrates. This would produce smaller files sizes, but would take a lot more time to encode.
DOES NVIDIA-CUDA support the playback of 3D blu-ray disc?
By Stears555 in forum Software PlayingReplies: 3Last Post: 29th Jan 2013, 02:40 -
AVCHD encoding enables CUDA
By kukkamies in forum Authoring (Blu-ray)Replies: 7Last Post: 14th Aug 2011, 17:55 -
nvidia announces cuda 4.0
By deadrats in forum ComputerReplies: 0Last Post: 28th Feb 2011, 16:37 -
memory usage of CUDA encoding
By sharkbite in forum Video ConversionReplies: 0Last Post: 25th May 2010, 22:36 -
Cuda Encoding Feedback: Anybody?
By themaster1 in forum Video ConversionReplies: 1Last Post: 9th Dec 2009, 12:09
