I recently downloaded a wmv file that for some reason has the audio too low. Is there any tool i could use to set it up to normal level? thanks!
Format : Windows Media
File size : 333 MiB
Duration : 21mn 26s
Overall bit rate mode : Constant
Overall bit rate : 2 172 Kbps
Maximum Overall bit rate : 2 168 Kbps
Encoded date : UTC 2009-01-21 11:32:47.320
Video
Format : VC-1
Format profile : MP@HL
Codec ID : WMV3
Codec ID/Info : Windows Media Video 9
Codec ID/Hint : WMV3
Description of the codec : Windows Media Video 9 - Professional
Duration : 21mn 26s
Bit rate mode : Constant
Bit rate : 2 100 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 30.000 fps
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.076
Stream size : 322 MiB (97%)
Audio
Format : WMA
Format version : Version 2
Codec ID : 161
Codec ID/Info : Windows Media Audio
Description of the codec : Windows Media Audio 9.2 - 48 kbps, 44 kHz, stereo 1-pass CBR
Duration : 21mn 26s
Bit rate : 48.0 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Bit depth : 16 bits
Stream size : 7.37 MiB (2%)
You could try windows movie maker or live movie maker, http://windows.microsoft.com/en-us/windows-vista/adjusting-audio-in-windows-movie-make...sked-questions . It will reconvert the video though but it's probably the easiest method.
Or use an audio editor like goldwave, audacity, dbpoweramp. If they fail to open the wmv directly then demux the audio from the wmv with for example Pazera Free Audio Extractor. Edit the audio and adjust the volume, convert it to wma. Multiplex it back to the wmv with Media Stream Editor (include in WME) ....yep tons of work... -
There's probably quite a few conversion programs which will copy the video while re-encoding only the audio. Off the top of my head Avidemux is one. It won't output WMV but if you use something like MKV it should work. Select "Copy" for the video and the desired audio type. Under audio filters select automatic as the gain mode.
Video To Video Converter should do a similar thing and let you keep the output as WMV. If memory serves me correctly it doesn't have an automatic gain setting so you'd need to specify the volume yourself by adjusting the slider in the audio section. I'd guess you might want to be careful not to turn it up too much. Open the file with Video To Video Converter and select WMV in the window which opens. On the right side select Copy for the video codec and adjust the volume in the audio section.
Hi8 -> DV -> Final Cut Pro = Low, low audio levels in captured video
By xmiller in forum Capturing and VCRReplies: 12Last Post: 14th Dec 2010, 16:59 -
Super low audio. Help!
By metadog in forum AudioReplies: 13Last Post: 7th Oct 2010, 15:58 -
Audio is extremely low
By Nintendo Fan in forum AudioReplies: 0Last Post: 26th Aug 2010, 15:43 -
How to reduce blocky artifacts in low res, low bitrate video
By The111 in forum Newbie / General discussionsReplies: 48Last Post: 20th Mar 2009, 18:29 -
Philips DVP5992/37 plays WMV Main Profile (Low Level)
By edDV in forum DVD & Blu-ray PlayersReplies: 4Last Post: 13th Dec 2008, 17:52
