Ok so I have been authoring and burning Bluray DVDs using MultiAVCHD but recently I played back the DVD only to find out I forgot to edit commercials on one of the video files. I accidentally deleted the .TS files which I had used to author and create the DVD.
So what id like to do now, Not sure if its possible is extract those files again so I can edit that 1 file which includes commercials and then burn a new Disc. I used Imgburn to burn the DVD and there are a few other options it gives you like "creating image file from disc" but not sure if this would allow me to do that or would be the easiest way. I once tried that just to keep a copy in my HDD of another project but it created a .Rar document that I could never figure out how to open or extract so Im very confused at this time.
Any help would be much appreciated, thank you!
*update
Yes instead of an .ISO image file it created a rar file, this one I was able to open and all the video files were there so I was able to extract the one I needed to edit!
It appears when getting files from a BD-R disc it creates a rar file but when I try the same from a DL-disc or standard DVD disc it then creates an ISO file, not sure how or why it does that. Its confusing to me but as long as it works im cool with that. -
Ok I think I've figure it out, when it asks to save the file I have 3 options, ( .Bin, .ISO and .IMG ) I was selecting the .ISO option which was creating the rar file which is still very weird because it had an .ISO extension.
I selected the .IMG option this time and it works but its still a big size file created, I will just rather keep the AVCHD folder just in case I wish to access the files within the project.
Can't get multiAVCHD to successfully create an AVCHD folder???
By jwmghf in forum Authoring (Blu-ray)Replies: 15Last Post: 17th Nov 2011, 12:37 -
AVCHD on hard drive: creating new AVCHD folder structure
By Phil_W in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st May 2011, 14:46 -
Help with already made AVCHD folder
By tge101 in forum Authoring (Blu-ray)Replies: 3Last Post: 17th Oct 2010, 19:16 -
Final Cut Pro 7 exits when importing avchd folder
By jovannig in forum EditingReplies: 0Last Post: 23rd Jan 2010, 17:24 -
AVCHD MTS numbering restarts at 0, impossible to copy to the same folder.
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 16th Jan 2010, 22:11
