  1. Have an .mkv and the sound is breaking/stuttering/comes and goes when i play on tv through the LG BD350. Plays on PC. This one will give subs from an srt on the TV. here is media info
    General
    Unique ID : 10355933205128880181906634339xxxxx0975 (0x4DE8CD46xxxxx68D4354595E3E9F068F)
    Complete name : C:\Users\vvvvvvv.mkv
    Format : Matroska
    Format version : Version 2
    File size : 1.62 GiB
    Duration : 1h 45mn
    Overall bit rate : 2 200 Kbps
    Writing application : Lavf52.94.0
    Writing library : Lavf52.94.0
    Video
    Format : AVC
    Format profile : Main@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 1 frame
    Format settings, GOP : M=1, N=15
    Codec ID : V_MPEG4/ISO/AVC
    Bit rate mode : Variable
    Maximum bit rate : 5 430 Kbps
    Width : 1 280 pixels
    Height : 688 pixels
    Display aspect ratio : 1.85:1
    Frame rate mode : Variable
    Original frame rate : 24.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Default : Yes
    Forced : No
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 1h 45mn
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Delay relative to video : 64ms
    Default : Yes
    Forced : No
    Oct 2005
    666th portal
    trash it. it has variable frame rate video. find something else.
  3. Originally Posted by aedipuss View Post
    what is wrong with that. Does it affect sound? video is fine
    Oct 2005
    666th portal
    it doesn't play on devices not designed for it. slows and speeds up video, audio can't be played correctly.
  5. Originally Posted by aedipuss View Post
    OK thanks. just curious is that why sound stuttered on tv?
    Oct 2005
    666th portal
    computers and iThings can play vfr. most simple players and tvs can't.
  7. Originally Posted by aedipuss View Post
    mmm my tv has played other vfr with sound intact
    Edit the new version is an avi works on tv sound fine. thanks
