Hi all, I am trying to open MPC-HC on Windows via command line at a specific position. E.g. with mplayer, you can use the -geometry argument to pass a size and location to open on screen. All I can see with MPC-HC is the monitor it opens on and size. Is there a way to pass a location to open at? (e.g. at 640x480 pixel position?)
Sorry, just to indicate, using the "remember last position" wont work, as I am looking to open multiple windows via the /new argument to open up in different locations on the monitors
If you select Help -> Command Line Switches in MPCHC you'll get a list of all the switches. It doesn't seem to let you specify the location, though you can specify the window size. You'll have to resort to setting the Registry values. They're in HKCU\Software\Gabest\Media Player Classic\Settings\LastWindowRect. The first 4 byte value is the x position, the second four byte value is the y position.
Thanks for the heads up. That's not the solution I was hoping for but it will have to do for now. I saw the switches but didn't see anything listed. Do you happen to know if its in the planned features? If not, I might ask to make a submission.
MPC opening 720p in 360p window
By darkdream787 in forum Software PlayingReplies: 22Last Post: 11th Aug 2013, 07:35 -
MPC-BE: how to display datacode (PGS-Subtitle) like in MPC-HC
By flashandpan007 in forum Software PlayingReplies: 0Last Post: 29th Apr 2013, 13:14 -
Always +125% video/Frame/Zoom size MPC-HC/MPC-BE?
By tigerb in forum Newbie / General discussionsReplies: 6Last Post: 8th Mar 2013, 15:57 -
How to move subtitle position in MPC-HC?
By Stealth3si in forum SubtitleReplies: 2Last Post: 14th Feb 2011, 05:46 -
MPC and MPC-HTPC Video Sizing
By ron spencer in forum Software PlayingReplies: 8Last Post: 15th Dec 2009, 10:52
