I get this when playing a video with MPC-HC: http://bildr.no/view/bWQxRnJr and this with VLC: http://bildr.no/view/K0pOSzJJ - How do I fix this..?
for mpc-hc, those pixels only last for few seconds and then they are gone. then after 30secs or something, they are back for few more seconds.... it does not matter whether it is a 480p or a 720p file... it happens whatsoever.
I am on a windows xp Fujitsu laptop.
some say software and hardware decoding, but how do i do that..?
sorry, my bad.. it is a toshiba laptop..
specs:
t2250 @ 1.73ghz
797mhz, 2gb ram
directx 9.0c
nvidia geforce go 7600 (v6.14.0010.8400)
that enough? -
I was just wondering if it happened with all your video files or just one video file...but I see now that you already mentioned that in the first post.
Has it always been like this?
You can disable hardware decoding easily by playing two video files at the same time in two video players. The first player will use hardware decoding and the later not.
Try also more players like smplayer, pot player.Last edited by Baldrick; 12th Aug 2013 at 14:05.
ah, my bad.. sorry about that. but yeah, it happens to all of my video files...
how do i disable hardware decoding then..?
another user said that i should try both software and hardware decoding.. how do i do that?
thanks for the help btw!
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Convert MKV files to AVI OR MP4 for Playing on Sony EX520 TV via UBS port
By premsoni4u in forum Video ConversionReplies: 2Last Post: 16th Jul 2011, 05:45 -
Playing MKV files on Plasma TV
By esabet in forum Newbie / General discussionsReplies: 5Last Post: 26th Dec 2010, 23:55 -
problem playing mkv hd files in my pc
By gotenks_fp in forum Newbie / General discussionsReplies: 1Last Post: 11th Mar 2010, 16:46 -
Sound problem while playing mkv files
By shorto in forum Newbie / General discussionsReplies: 1Last Post: 21st Jun 2009, 05:02
