  1. Hello.
    In the last month or so, i have this problem.
    PowerDVD can't play Blu-rays.
    It pops up the message of the title, and it can't play them.
    The funny thing is that this doesn't happen all the time!
    Sometimes, it works!
    I mean just now, i thought to check just in case, and it worked. It played the Bluray!
    Then, i restarted my pc, and that message again appeared when i try to play the Bluray.
    (when it pops up that message, the region of the player has vanished and you have 0 changes for BLuray region).
    I have tried many versions of PowerDVD. None works.
    any tip?
    Maybe time to test something else like TMT. Try the trial first and see how it works for a month.
  3. I was using TMT but I had other problems in the last days (audio pops).
    Then i used WinDVD and i had other problems explained here: https://forum.videohelp.com/threads/357738-WinDVD-panel-keeps-appearing-in-fullscreen!?...96#post2256896
    Ok, it seems i had to write here to find the solution after a month or so!! hehe!
    I followed the advice of John768 here:
    http://forum.cyberlink.com/forum/posts/list/105/27357.page
    i didn't find all the files that he said to delete, but I deleted a couple.
    anyway, i think my problem was strongly linked to this:
    Panda antivirus had been sending to quarantine the CLhelper.exe in the past month. Don't know why.
    Anyway, these are the steps that i did, and the problem is SOLVED now!
    1) Deleted as many files i could find from the ones John768 mentions.
    2) Prevented powerDVD from connecting to internet through Panda's firewall
    3) made an exception from quarantine for the Cyberlink folder (if i didn't do that, the Clhelper.exe would be constantly sent to quarantine)
    4) restored CLhelper.exe to its initial folder
    Now, everything works fine as it seems!!
