Hi there new to the forums. I have been encoding with handbrake for quite some time know but every time I encode a video using the constant frame rate setting my videos always turn out to use the variable frame rate. I encode to mp4 container with h264 and have tried everything to get it to work to no avail. When i use mkvmerge to mux it into a mkv it then goes to constant frame rate. Was wondering if anybody has had an issue like his before and if they where able to solve it any help would be very grateful.
I don't use Handbrake much and I hardly ever use its mp4 output. But I know the program has some kind of bug where it likes to switch the CFR/VFR back to VFR when you switch tabs and fiddle with other settings or something. I haven't figured out exactly when it happens. But when I use the program I make sure CFR is set just before pressing Start.
You could try latest beta build from http://sourceforge.net/projects/handbrake/files/Betas/QSV/
Or try VidCoder. It's based on handbrake.
Handbrake Issue - Playing 2 audio tracks simultaneously
By newbcake in forum Newbie / General discussionsReplies: 2Last Post: 7th Aug 2013, 08:22 -
Handbrake: Blu-ray Disc to MKV Help! Video Stretching Issue!
By Mickey79 in forum Blu-ray RippingReplies: 3Last Post: 22nd Feb 2013, 13:01 -
Handbrake Lowering FPS issue (29.970 to 23.976) - Should I be concerned?
By kingaddi in forum DVD RippingReplies: 20Last Post: 3rd Sep 2012, 01:16 -
Handbrake QuickTime Encoding?
By jfharper in forum Video ConversionReplies: 5Last Post: 29th Mar 2012, 16:16 -
Trouble converting VOB to AVI using Handbrake (audio issue)
By binvisions in forum Video ConversionReplies: 1Last Post: 1st Aug 2009, 04:28
