Sorry if this has been answered before, but I couldn't find it when I searched.
Sony BDP-S470
Vizio ES370
ATI AIW MMC 8.8
MPEG-2
352X480 NTSC
My recordings appear to be changed from 4:3 to 16:9 and I don't know which one.
I'm sure I probably have a setting wrong but don't know which.
I'm using my computer as a DVR, I transfer the mpeg to a flash drive and pop it in the Sony for viewing
Any help would be great
Results 1 to 12 of 12
352x480 is HalfD1 and shows up more like 9:16 in some software apps....MPEGVCR being one of the apps.
I've also experimented recording with 640x480 and 720x480 and they all display on the TV like they've been converted from 4:3 to 16:9
you sure you don't have your tv set to stretch everything to full screen?
The Vizio does have 4 setting, Normal Wide Panoramic and Stretch. Right now I have it set at Normal.
Didn;t you omit a few things?
Recording what source? Tape? TV? cable box?
Capture card? ATI MMC comes with a capture card, right?
MediaInfo: https://www.videohelp.com/tools/MediaInfo
Gives info about videos.Op-en a video with it, Click "View.." -> "Text" and copy/paste the text into the forum. Or, save the report as a text file and post here.Last edited by sanlyn; 25th Mar 2014 at 09:33.
Possibly. The Vizio setting sounds OK (my Sony is similar). The player may be set up for a 4:3 TV where yours is 16:9. You should go into the setup menu and make sure it's outputting for a 16:9 or widescreen TV set.
Click on the MediaInfo link and post the text screen of the video. -
Went back and triple checked my settings on the player and it was set to 4:3 TV!! All better now!!
Thanks for the help -
Assuming the video streams (on a video blu-ray disc and/or flash drive) are appropriately flagged as (16:9 or 4:3), they will appear in the correct aspect ratio if played on a Sony blu-ray player connected through HDMI provided the following settings are chosen on the blu-ray player:
- setup>screen settings>TV type>16:9 or 4:3 (according to the connected TV; almost always 16:9, I haven't encountered a 4:3 TV yet with HDMI input)
- setup>screen settings>screen format>fixed aspect ratio (instead of original)
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
Aspect Ratio Question
By rede96 in forum Newbie / General discussionsReplies: 5Last Post: 14th Aug 2011, 04:17 -
Aspect Ratio Question + Some
By Alexander4444 in forum Video ConversionReplies: 7Last Post: 9th May 2011, 02:17 -
By kelticvixen in forum Newbie / General discussionsReplies: 3Last Post: 12th Jan 2009, 13:27 -
Question about aspect ratio and resolutions
By KMJvet in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Dec 2008, 19:01 -
aspect ratio question
By brianhj in forum Video ConversionReplies: 6Last Post: 16th Aug 2008, 12:54
