If you're running a recent CPU (last 10 years) and windows 7 or greater you can use the AVX2 version; I doubt if there is that
much difference between the Clang or other version; one may be slightly faster that the other.
If you're not sure about the CPU, you can use cpuz to see if avx2 is listed
https://www.cpuid.com/softwares/cpu-z.html
				Results 91 to 100 of 100
	64 bit version goes in the plugins64+ folder. 32 bit version goes in the plugins+ folder.
	Mostly. There are a few plugins that have to go in the plugins or plugins64 folders instead.
 Note that plugins (and AVSI scripts) in the plugins folders automatically load every time AviSynth is started. Some people prefer to load plugins manually in their scripts instead. They place them somewhere else and use LoadPlugin("c:\path\to\pluginName.dll") within their scripts instead.
	fwiw, I found this video to be useful when installing avisynth+ https://www.youtube.com/watch?v=C4PyyQoz6eo&t=1313s
	I'll probably delete the zip file at some stage as it'll eventually become out-dated, but here you go. It doesn't include the plugins that Avisynth installs such as DirectShowSource.dll. They'd probably be fine, but just in case they're not compatible with the version of Avisynth you installed, and because you should have them anyway, I didn't include them.
 If the plugins have an AVX2 version it'll probably be the version in the zip file, so if your CPU doesn't support AVX2 you might have to replace them with a version it supports (there won't be many of them, but I've no idea which ones they'd be).
 The help files folder includes function help files too (QTGMC for example). The zip file only includes plugins though (aside from the couple of plugins that also have functions), so some of the help files aren't needed, but I didn't bother sorting through them.
 64 bit plugins.zip (55.2 MB)Last edited by hello_hello; 19th Jul 2024 at 18:13. Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
 Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview)
  Video Converter w/ denoise, deinterlace filtersBy Johnbil in forum Video ConversionReplies: 3Last Post: 14th Nov 2012, 22:26
  high quality deinterlace, resize and denoise in AviSynthBy codemaster in forum Video ConversionReplies: 4Last Post: 21st Jun 2012, 18:04
  avisynth denoise filter applied only from frame x to frame yBy codemaster in forum Video ConversionReplies: 1Last Post: 26th Apr 2012, 13:22
  Which filters I should use for this anime? (avisynth)By Cloudstrifeff7 in forum Newbie / General discussionsReplies: 6Last Post: 13th Dec 2010, 08:47
  [Avisynth] What are the filters used in this video?By Cloudstrifeff7 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Apr 2010, 10:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
