Hi. Greetings to all.
First of all, let me tell you that I had been busy (I have a Cancer Patient in my family) during these days and couldn’t answer here; looking for a pardon for that.
Now let me tell you that I have opened a NEW THREAD here –
https://forum.videohelp.com/threads/414296-Blu-Ray-to-576p-720p-avsPmod-MeGUI-Subtitle...p2Sub-MKVTooln
Please post there or answer there if you so wish because in that case, not only me, but all novice users like me could get help from your kind answers or suggestions also.
For primal information, I use the MeGUI 2913 (64-bit) version for encoding purposes (for DVD, 1080p, and 2160p), but I don’t know how to use the handbrake. So all of my queries are directly related to MeGUI where I can understand and might be able to answer conceptual stuff related to handbrake. I don’t use the advanced versions of MeGUI as after 2913, the entire layout of it has been changed, and I dislike learning new things until the thing becomes indispensable.
Now let me tell you what I did to fetch a temporary solution; I mentioned earlier that I had a large bag of .dll files for avisynth+ (there it each .dll file was categorized into four bags viz. 32, 32+, 64, 64+); I copied and pasted them minutely. The LSMASHSource.dll was disturbing initially; then I just downloaded another 64-bit LSMASHSource.dll from the 'dll library' and precisely, that’s how reached a temporary solution.
Anyway, LSMASHSource.dll is not a big problem as of now; - rather it is the QTGMC without which I can’t imagine encoding DVD and in some critical cases, some Blu-rays; especially the extra parts.
My problem is I forgot how to execute some crucial .dlls like fftw3.dll, libfftw3f-3.dll i.e. the whole pack of FFT3DF Filter; as a result, I cannot use Preset and hence, EZDenoise, Rep module, DCT etc. I knew one easy way; - but forgot as I did it ages ago in my 32-bit machine; only the last thing I can remember; - renaming libfftw3f-3.dll as fftw3.dll or something like that in the 'System32' folder.
I can’t use the MCTemporalDenoise module either due to a non-functional FFT3DF Filter. I have become unable to make use of Yadiff also.
Could any kind soul tell me how to register it through the .cmd prompt?
BTW, I have all versions of QTGMC with me.
Another problem is related to Audio Encoding which I’m facing after shifting from 32-bit to 64-bit; - I cannot downmix 5.1 to stereo i.e. 2.0. I use FFmpeg AC-3 as Encoder where the preferred Decoder is LWlibavAudioSource.
For a piece of your possible positive information, Nero Encoder, Nero Decoder, and the ffmpeg have been installed in the eac3to folder of MeGUI.
Any kind of expertise voice is there upfront?
Looking forward to this handholding support.
Sincerely,
Results 61 to 90 of 100
64 bit fft dlls go in c:\windows\system32
32 bit fft dlls go in c:\windows\syswow64
They are system dll's and will load automatically when you use AviSynth or any other program that requires them. -
What I dont understand is why nobody mentions that when a newb is asking about denoising their video, they are really looking to degrain their video. I messed around with denoisers for months and was only partially happy with the results but then stumbled on TemporalDegrain2 and have never looked back. Yeah it takes longer, but the results are worth it.
Something like:
SetFilterMTMode("DEFAULT_MT_MODE", MT_MULTI_INSTANCE)
video_org=FFmpegSource2("Your Video Name Here.avi", atrack=-1) # no Lagarith installed
# cropping
crop_left=0
crop_top=2 # | 720-(8+8)x576-(2+10)=704x564
crop_right=16
crop_bottom=10
video_org_crop=video_org.crop(crop_left,crop_top,-crop_right,-crop_bottom)
### deinterlacing
deinterlaced=video_org_crop.AssumeTFF().QTGMC(pres et="slow", matchpreset="slow", matchpreset2="slow", sourcematch=3, tr1=2, tr2=1, NoiseTR=2, sharpness=0.1)
### convert to YV16
deinterlaced_yv16=deinterlaced.convertToYV16()
### denoising - choose your level here
#denoised_yv16=deinterlaced_yv16.TemporalDegrain2( degrainTR=3)
#denoised_yv16=deinterlaced_yv16.TemporalDegrain2( degrainTR=2,grainLevel=2,postFFT=1,postSigma=1)
denoised_yv16=deinterlaced_yv16.TemporalDegrain2_f ast(Strength=10)
### convert to YUY2
denoised=denoised_yv16.convertToYUY2()
## convert to YV12
denoised_yv12=denoised.convertToYV12()
### sharpening
sharpened_yv12=denoised_yv12.LSFmod(defaults="slow ")
### convert to YUY2 with chroma from YUY2 color space
sharpened=sharpened_yv12.convertToYUY2().MergeChro ma(denoised)
#sharpened=sharpened_yv12.convertToYUY2()
### add borders
video_rest=sharpened.crop(0,0,-6,0).spline64resize(640,480)
return(video_rest)
prefetch(10) -
Because TemporalDegrain with degrainTR greater than 1 can destroy details. And it is not a universal way.
In addition, only at 10 bits (or more) does it not cause combing (possible that with 8 bits this can be compensated by parameters). And this script should have such a bit depth.Last edited by rgr; 20th Jun 2024 at 18:24.
Yes, TemporalDegrain2 is excellent
Just like any other denoiser. The temporal radius is just one of the key paramters, although the more important.
There is no universal way, nor a single denoiser, nor a single set of its parameters which can blindly work. Any video is unique, and requires a specific approach. (But TD2 in general works quite well in many cases)
I never used a 10-bits conversion in any of my scripts for VHS capture. -
Yes, but TD2 is very prone to that. It also has other flaws, it can't handle well the first frames after a scene change.
I gave up on 8 bits some time ago. With strong denoising, this guarantees banding (not combing as I wrote incorrectly). I always work in 16 bits -- 10 is the minimum. Besides, I posted here screens of what banding leaves TD2 at 8 bits. -
I find these settings to temporaldegrain to get the job done usually. Not too destructive and the ghosting/blending of pieces of frames are nearly nonexistent.
A max SAD1 of 200, and SAD2 of 150 is about as high as I will go.Code:TemporalDegrain(sigma=16, degrain=1, ov=4, blksize=8, gpu=false, sad1=125, sad2=100, hq=0)
You can make it even less destructive with some luma weighting. It will be a bit less effective though.
Code:source = last TemporalDegrain(sigma=16, degrain=1, ov=4, blksize=8, gpu=false, sad1=125, sad2=100, hq=0) MergeLuma(last, source, weight=0.4)
TemporalDegrain2 not TemporalDegrain
https://forum.doom9.org/showthread.php?t=175798 -
Smears out more detail than I want and had some side effects I didn't like. It's a good filter if spotless is your goal or if working with live action sources, but it doesn't preserve animation detail as well for me.
I'll have a look at the updated version. Been a while since I looked at it.Last edited by killerteengohan; 2nd Jul 2024 at 18:45.
The doom9 thread says Avisynth+ 3.7.1 is the minimum requirement for TemporalDegrain2 from version 2.4
Any version of Avisynth prior to Avisynth+ 3.6.0 will come to a sudden halt if there's square brackets in a script or function.
http://avisynth.nl/index.php/User_defined_script_functions#Facts_about_user_defined_script_functions
It's unfortunately something you can't even work around using Avisynth version checking for backwards compatibility, because even though you can add conditions to a function, such as pseudo syntax like:
The parser still needs the entire syntax to consist of characters it understands, and for older versions of Avisynth, "[" and "]" don't qualify.Code:if (AvsBuildNum <= 2294) DoThis else DoThat
Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview) -
Sorry, the forum automatically converts the text to links for software when you first submit a post and I typed Avisynth before editing the post to correct it to Avisynth+ <- but this should take you there.
Edit: The automatic linking doesn't seem to work for Avisynth+. It might need to be typed as Avisynth Plus or something.....Last edited by hello_hello; 14th Jul 2024 at 09:28.
As it's been a fair while since an official release of a new version, the guy responsible for 99% of the Avisynth+ development posts a link to a new build at doom9 now and then for people to test. Mainly to make sure bugs have been squashed. I've been using this one for a while without any issues. There's no installer but you can just replace the old dlls with the new ones.
Avisynth+ 3.7.3post test 14 (20240131 - r4066)
(see post #80 for a link to newer builds)Last edited by hello_hello; 15th Jul 2024 at 14:53.
If you haven't come across it yet there's a link to a text file here for automatically setting the correct MT mode for (older) plugins that don't register their MT mode with Avisynth.
You just need to save the text file with an avsi extension and add it to the Avisynth Plus plugins folder so it'll auto-load. The idea being you shouldn't need to mess around with SetFilterMTMode() in scripts very much and simply adding Prefetch(?) to the end of a script will enable multi-threading.Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Here's a link to the Avisynth Plus unofficial builds page at gitlab. I'd forgotten it existed. There's more recent builds there than the one I linked to yesterday.
https://gitlab.com/uvz/AviSynthPlus-BuildsAvisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
I downloaded the BDRB zip file and the instructions say Avisynth needs to be installed separately.
BDRB doesn't seem to include very many Avisynth plugins. The ones in it's tools folder are:
AudioLimiter, AutoCrop, decomb521, DGIndex/DGDecode, FRIMSource, nicaudio, SmoothDeinterlacer and tivtc.
There's newer versions of some of them, but I doubt any of them will have trouble working with Avisynth+.
I'm assuming you use other Avisynth plugins too, but the BDRB plugins seem to be 32 bit.
Keep in mind you can install both the 32 and 64 bit versions of Avisynth+ at the same time, and there's probably no reason why 64 bit Avisynth+ can't be installed along-side Avisynth 2.6. The installer lets you choose to install both 32 and 64 bit versions, or just one of them if you prefer. A fresh Avisynth+ install of both versions creates four plugins folders (I think). Two for 32 bit plugins and two for 64 bit plugins. I assume one of each is for backwards compatibility. Functions will work with either version. The changed auto-loading of plugins in Avisynth+ is explained here: http://avisynth.nl/index.php/AviSynth+#Plugin_Autoloader
No doubt BDRB will continue to load the plugins in it's own tools folder with LoadPlugin in it's scripts.
There's very few plugins that don't have 64 bit flavours now, so you can take your time downloading the 64 bit plugins you need while still using 32 bit Avisynth+. The version of Avisynth+ that runs would probably just depend on whether the program opening the script is 32 bit or 64 bit. I'll confess I've never installed both flavors at the same time myself, as I just switched from 32 to 64 bit when I built a new PC a while back.Last edited by hello_hello; 17th Jul 2024 at 15:01.
Yes, you can install both. And which you get depends on the bitness of the editor/encoder/player you use to open the AVS script. A 64 bit program will get 64 bit AviSynth(+) and 64 bit filters. A 32 bit program will get 32 bit AviSynth(+) and 32 bit filters. The 64 and 32 bit systems can't "see" each other or each other's filters.
64 bit AviSynth used to have a paucity of filters and and abundance of bugs. But most filters are now available in 64 bit versions and 64 bit AviSynth is very stable. I wouldn't bother installing 32 bit AviSynth unless you have a specific need for it or some old filter that's not available in a 64 bit version. -
Yeah, I just did... But, I don't know what the hell to do with it (I just posted a separate thread entitled 'Avisynth+ Plugins') I SWEAR, I've never ever come across a program like AVS (or now AVS+) that is so bloody confusing! Does the new program just load plugins from my old AVS plugins folder, or do I now have to put in a bunch of plugins in the now empty Plugins+ or Plugins64 or Plugins64+ folders...? and WHICH bloody ones? GEEZ...
If you installed both the 32 bit and 64 bit versions, then 32 bit plugins can go in either the plugins or plugins+ folder, and plugins64 or plugins64+ for 64 bit plugins. Avisynth+ should have added a few plugins to one of the 32 bit and 64 bit folders (if you installed both versions).
32 bit Avisynth+ checks the plugins and plugins+ folders for plugins to auto-load and the 64 bit version checks the other two. It doesn't matter if you only use a single plugins folder for 32 bit plugins or you use both. Same for 64 bit plugins. As I have a lot of plugins and functions auto-loading I put dlls in one folder and functions in the other, but that's up to you.
64 bit Avisynth+ won't auto-load plugins from your old plugins folder as they're 32 bit. You need to download the 64 bit version of each plugin, and if your old plugins folder contains functions, you'll probably need to copy those and add them to either plugins64 or plugins64+.
I also create another folder called "Plugins Help" and create a shortcut to it. Then as I'm downloading plugins, I put any included help files in that folder.
Many plugins hosted on the Avisynth wiki only have a link to a single zip file that contains both 32 bit and 64 bit versions of the plugin. Sometimes they're in separate zip files, and occasionally there's only a 32 bit version and you need to hunt down a 64 bit version with google, if one exists.
An Avisynth+ installation of both flavours adds the 32 bit versions of Avisynth.dll and DevIL.dll to the Windows/SysWOW64 folder. The 64 bit versions of those dlls are added to the Windows/System32 folder (and yes it seems like it should be the other way around but that's how Windows works).
There's a couple of other dlls required by some plugins and they should also go in the SysWOW64 and System32 folders. You might as well just add them now and avoid any misery later. They come from here, but to make it easier for you:Last edited by hello_hello; 18th Jul 2024 at 11:58.
As a test to make sure Avisynth is working you could download the 32 bit and 64 bit flavours of AvsPmod. It comes in zip files you can just unzip somewhere.
If you run the 64 bit version of AvsPmod, type Version() into the text area and then click the play button to open the video preview, you should see something like this:
[Attachment 80806 - Click to enlarge]
If you also have a 32 bit version of Avisynth installed, doing the same while running 32 bit AvsPmod should show you the 32 bit version of Avisynth.
It doesn't mean you've added plugins to the correct plugins folders, it just means Avisynth itself is working.Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Thank you kindly for all your help! I'm still really confused as to what to do with all my old 2.6x plugins? Anything? Is there one place I can go to copy a bunch of plugins to put in my AVS+ plugins64 (or whereever folder) Still very confusing, sorry...
If I could just go somewhere and simply copy a bunch of plugins OR find a pack of them that installs in the right place automatically, that would be nice!
For example, I downloaded AWarpSharp and this is what is in the folders:
Volume in drive F:\ is Arch 3 SndZ
Directory of F:\EXECUTABLES\aWarpSharpMT_v2_1_9\x64\
. <DIR>
.. <DIR>
Release_clang_W7 <DIR>
Release_clang_W7_AVX <DIR>
Release_clang_W7_AVX2 <DIR>
Release_W7 <DIR>
Release_W7_AVX <DIR>
Release_W7_AVX2 <DIR>
Release_XP <DIR>
Release_XP_SSE2
Directory of F:\EXECUTABLES\aWarpSharpMT_v2_1_9\x86\
. <DIR>
.. <DIR>
Release_W7 <DIR>
Release_XP <DIR>
Release_XP_SSE2
What the living HELL do I do with these?!! Talk about confusing. So, if I go and try to find individual scripts, this is what I get, a HUGE confusing glob of stuff I don't know what the hell to do with.
I'm REALLY hating AVS right now!
Video Converter w/ denoise, deinterlace filters
By Johnbil in forum Video ConversionReplies: 3Last Post: 14th Nov 2012, 22:26 -
high quality deinterlace, resize and denoise in AviSynth
By codemaster in forum Video ConversionReplies: 4Last Post: 21st Jun 2012, 18:04 -
avisynth denoise filter applied only from frame x to frame y
By codemaster in forum Video ConversionReplies: 1Last Post: 26th Apr 2012, 13:22 -
Which filters I should use for this anime? (avisynth)
By Cloudstrifeff7 in forum Newbie / General discussionsReplies: 6Last Post: 13th Dec 2010, 08:47 -
[Avisynth] What are the filters used in this video?
By Cloudstrifeff7 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Apr 2010, 10:40
