Hello all,
I've been backing up my DVD collection and putting it on my NAS to stream through my bluray player, and the encoding is working fine. I'm using x264 CRF 18 or 20 and just muxing the studio audio. The problem I'm having at the moment is that some of my longer movies are 2 disc sets. I know DVDfab can merge them, but I prefer freeware or manual tools. It would be easiest is someone could point me to software or a guide which will help me to combine the two "titles."
My ripping process:
Except where it won't get past copy-protection, I use the ripit4me frontend to rip movie only (in other cases slysoft)
decrypt the dvd and if necessary clean up vobs, then I send it through DVD shrink to output without compression and without 1gb file splitting.
I suppose I could just encode separately and join with mkvmerge, is this the best way to do it? I use staxrip to encode, so I can cut out extra frames if there's added padding.
I'm just wondering if anyone out there has general advice on this; any suggestions are welcome. I'm pretty knowledgeable as far as DVD ripping goes, been doing it for about 7 or 8 years, but I know there are people around here who know a lot more than me. Thanks for your help![]()
darnit i dont know how i ended up in this subforum, I guess I clicked the wrong one. sorry XD
thanks for the quick reply, I haven't tried that one yet, but I'll take a look.
Put both discs on the hard drive, renumber the second part of the movie to follow the first so that all the VOBs are numbered consecutively, and then move them into the same folder. Take it from there.
Although you can try it. DVDRemake Pro won't do you any good as it'll create separate VTS's within a new DVD, rather than joining the two parts into a single title/VTS as you want. After it's done the parts will still be separate, even if within the same DVD. Here's the guide:
http://www.dimadsoft.com/dvdremakepro/ht_merge_full.php
what do i do to make a dvd movie small enough to fit in one disc?
By polka in forum Authoring (DVD)Replies: 3Last Post: 24th Mar 2012, 02:53 -
Possible to merge projects into one movie? Using Pinnacle 11
By goldeneye in forum Newbie / General discussionsReplies: 2Last Post: 4th Dec 2011, 21:15 -
Very basic question...... how can I merge mpeg files and make a movie
By True Colors in forum Newbie / General discussionsReplies: 5Last Post: 30th Oct 2009, 17:45 -
How to merge subtitle file with movie when it is being burnt ?
By dilanalex in forum SubtitleReplies: 3Last Post: 7th Apr 2009, 04:15 -
Empty DVD Disc with a movie on it ???
By macbuz in forum MacReplies: 8Last Post: 8th Jan 2009, 13:42
