hello forum
ive been pointed in this direction by the guys on AV Forums, as they say you guys are the experts...and i have a problem!
I have a video of my wedding day speeches that no longer plays.
It is in mp4 format, 2.5gb in size.
It was ok a few months back and has been watched in its entirety.
But now it freezes at 8mins. No audio and the video just freezes, like a screen cap.
I have tried various file fixers but found none to work or have any real functionality.
I have converted to avi, which results in the same problem.
Also tried multiple video players - windows media, media player classic and VLC. No joy
Also tried multiple computers with no luck
Just wondered if anyone could help as its the only video of the speeches that was made!
Results 1 to 17 of 17
AnonymousGuest
You could try "remultiplex" it, open it in mymp4boxgui and make a new mp4. It will probably fail though. Then try video repair tool and see if it can repair it. Try the trial first(repair half video).
AnonymousGuest
ive tried mp4box, no luck
heres what mediaino says on it:
General
Complete name : C:\Users\rich\Videos\wedding speeches.MP4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 2.53 GiB
Duration : 28mn 59s
Overall bit rate : 12.5 Mbps
Movie name/More : OLYMPUS DIGITAL CAMERA
Encoded date : UTC 2012-09-01 17:58:06
Tagged date : UTC 2012-09-01 17:58:06
Origin : Digital Camera
Video
Format : AVC
Format profile : Baseline@L4.0
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=30
Codec ID : avc1
Duration : 28mn 59s
Bit rate : 12.2 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.197
Stream size : 2.48 GiB (98%)
Language : English
Color primaries : BT.601 NTSC
Transfer characteristics : BT.709
Matrix coefficients : BT.601
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 28mn 59s
Source duration : 28mn 59s
Bit rate mode : Variable
Bit rate : 128 Kbps
Maximum bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 26.4 MiB (1%)
Source stream size : 26.4 MiB (1%)
Language : English
Tagged date : UTC 2012-09-01 17:58:06 -
AnonymousGuest
I've tried muxing but to no avail.
I'm not really sure what it is to be honest. Or if I'm doing it correctly. -
So neither program worked? Your file might be corrupted due HDD failure? That would come on my mind.
There must be some repair tools around, they might help. Check here on videohelp: https://www.videohelp.com/tools/sections/video-repair-fix
First, I'd just try to load your file to videoeditor and edited out part that gives problem, check the time when it stops playing, try to use Avidemux for example and cut out that part, save without re-encoding. Try not to scroll through that part that gives problem. -
AnonymousGuest
Thanks for the suggestions. But I can't cut out parts of the video as its a wedding speech. If I cut parts out it will make no sense!
I've tried several video fixer programmes and had no luck.
The PC it was originally on had no HDD failure and was backed up on a USB stick. -
So now it gives you the same problem in both cases, playing from HDD and USB stick too?
AnonymousGuest
Does the timing of you backing the file up to USB stick coincide to about when the file stopped playing properly?
AnonymousGuest
No not really.
My dad had it on his lappy and a USB.
He'd watched it several times from both and then when tryin to show me it this happened!?
Does the media info I posted above give any clues.
I'm not a media buff at all so I'm totally stumped. (Although I am a bit of a tech and computer nerd!) -
No, the media info doesn't seem to hold any clues.
What happens when you try remuxing, say with mkvmerge, you get an error or does the resulting mkv file behave the same as the mp4? -
AnonymousGuest
this is what i get when trying to mux with yamb
[16:56:51] : YAMB 1.6.0 started !
[16:56:52] : OS type detection...
[16:56:52] : Professional (version 6.1, Build 7601 : Service Pack 1)
[16:56:52] : Checking MP4Box location...MP4Box found.
[16:56:52] : Checking MediaInfo.dll...0.7.1.2 found.
[16:58:50] : Muxing started...
[16:58:50] : Importing & Writing streams...
[16:58:52] : Error importing C:\Users\rich\Desktop\P9010238.MP4: IsoMedia File
[16:58:52] : Muxing failed.
Problem with sound - MP4 video from CD
By Ves in forum Newbie / General discussionsReplies: 5Last Post: 27th Jan 2012, 03:43 -
problem with mp4 video files
By akyrooo in forum Video ConversionReplies: 11Last Post: 20th Dec 2010, 12:54 -
Video COnverter Problem{conversion to mp4}
By dharmil007 in forum Video ConversionReplies: 2Last Post: 27th Jun 2010, 08:00 -
avidemux newbie: mp4 in; avi out has no video; mp4 out has washed out video
By nonexistent_entity in forum Video ConversionReplies: 1Last Post: 22nd May 2010, 14:46 -
Any Video Converter .mp4 problem with Moto Razr
By BayouBill in forum Video ConversionReplies: 3Last Post: 28th Jul 2009, 07:13
