I have some anime chapters in HD of 230~250MB file-size each at 720p. And I want to re-encode them to SD by reducing the resolution to 480p, but the problem is that the result video is muted.
I used MeGUI for the process, please help
I can't comment directly on megui since I don't use it but there must be a "copy stream" option available somewhere.
Or if its command line most likely -a copy so you copy the audio without altering it.
You can also use ripbot264 to reencode to 480p (in the picture properties setting window) and copy the audio using "copy stream" in the audio selector box.
Edit - also when you say copy to sd are you trying to make a dvd from it? If so dvd audio must either be pcm, ac3 or dts with an ac3 track. Things like mp3 and aac are not dvd compliant.
Read this for more on what is part of the dvd spec if that is what you are trying to make:
https://www.videohelp.com/dvdDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
No, I'm not planning to make a DVD, just save some disk space. And also there are other details that I didn't comment: I have K-Lite codec pack, It's not problem of the video since it plays perfectly on Windows Media Player, and finally, I used VirtualDubMod to extract and the audio and got a very strange result, the audio played like with overspeed, It sound like Chimpunk. So I don't understand what is the problem, I will try the software you recommended.
When I use MeGUI I first create the AviSynth script with the tool that MeGUI has integrated, then I load the script, configure the profile for video and audio, and then I use the auto-encode option
PD: for the audio, just edit the script to change the audio option to true.
PD2: ripbot264 worked fine, but it has only a few options to configure the encoding parametersLast edited by lordscales91; 11th Aug 2013 at 12:50.
Ripbot can do whatever avisynth can. go into picture properties and select show script.Originally Posted by lordscales91
Also you can go into the different configuration screens and set basically whatever you want. It depends on which version you are using to know which screen to go into. But basically you can change anything you want in ripbot.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
I lost audio for mp3's, .avi, mpg files, and Audio Switcher::Out
By HartsVideo in forum Software PlayingReplies: 13Last Post: 14th Oct 2012, 21:20 -
Lost Audio on kid's video project. Confused about : .HO. .adv, .HDP files?
By tmh in forum AudioReplies: 2Last Post: 7th Dec 2011, 18:50 -
AVStoDVD crashed on audio encoding.. have m2v video file, but no audio
By arcooke in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2010, 15:18 -
What format for encoding to get both Audio and Video tracks?
By DaveFresco in forum Video ConversionReplies: 3Last Post: 2nd Jun 2010, 03:48 -
Add new audio to DVD without re-encoding video??
By vulture99 in forum Authoring (DVD)Replies: 9Last Post: 20th Nov 2008, 16:23
