I need help...
I'm pretty new to this stuff and need help on how to cut an .mpg-file.
I have an .mpg-file that is 0.2 MB(!!!) too big to fit on a 700 MB cd-r.
How should i do?
/ jonma :-?
you do know that you can fit ~800MB of VCD or SVCD on a 700 MB file, right?Originally Posted by jonma949
yeah, i know, this file that i need to cut is 805 MB, but NERO wont burn it.
I have another file that is 0,2 MB smaller, and NERO burned that one... -
You probably need to set Nero to overburn (but if it burned the last one, this should already be set - unless you recently upgraded NERO). Go to FILE -> PREFERENCES -> EXPERT FEATURES (I think). Somewhere in there is an option that you check that will allow overburning - also (somewhere ELSE in the preferences section) there is a MAXIMUM amount that NERO will try. Just move this value a little higher.
A CAVEAT: If you set to overburn, you are running the risk that your CDR doesn't have the particular capacity that you need (this cap varies from brand to brand - and maybe even lot to lot). NERO has a utility called CDSPeed that is packed with the upgrade that will allow you to test the maximum overburning capabilities of your particular CDR blank (I believe that it is in a directory below NERO called UTILITY). -
Is it possible to overburn 4.7G DVD-R's as well?Originally Posted by fantomlord
use TMPGENC > File > Mpeg Tools > Merge&Cut > add > editOriginally Posted by jonma949
This will let you remove parts you don't want, but does NOT re-encode the movie.
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
Cutting a MPG FILE
By peekayem in forum EditingReplies: 3Last Post: 16th Mar 2008, 10:06 -
cutting out scenes without loss / converting mpg to avi
By denadel in forum EditingReplies: 3Last Post: 19th Jan 2008, 09:18 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47
