Results 1 to 13 of 13
  1. Member vhelp's Avatar
    Mar 2001
    New York
    not too long ago i downloaded mpc-hc, but not sure i installed it or it played as-is. anyway. i am working on gui and was trying to play an encode i made when it popped this message:
    i donloaded the latest per the link (menu\help\home page) and attempted to install, but it wants service pack 3, which i will NOT install. i had a lot of trouble with it in the past and it took a while to uninstall it. is there another download that has it that i can install w/out sp3 or better yet, has anyone a modified version that works no matter what ?
    also, as it turns out, it displays this message for all the videos i try to play.
    thank you, in advance.
  2. DECEASED
    Jun 2009
    Heaven
    Try the following
    ( warning, I don't know if this will work or won't work, play at your own risk ):
    open the installer with 7-Zip (or w/ Universal Extractor, as a last resource),
    and unpack the contents to a separate folder;
    locate the file DXSETUP.EXE and run it, *perhaps* it doesn't check if SP3 is installed
  3. You might try MPC-BE. Very similar to MPC-HC, and it is a little more forgiving, There's a portable version available.
    [EDIT] I see El Heggunte recommended pretty much the above fix to a user (in the MPC-BE comments section ) who had your same problem on Win7. And evidently it works. Anyway, I think MPC-BE is a better player than MPC-HC.
    Good luck.
    Pull! Bang! Darn!
  4. Member vhelp's Avatar
    Mar 2001
    New York
    7z did not work as expected. all the files are (in the root) are
    [folder].rsrc
    .bss
    .data
    .idata
    .itext
    .rdata
    .text
    .tls
    [0]
    CERTIFICATE
  5. DECEASED
    Jun 2009
    Heaven
  6. Member vhelp's Avatar
    Mar 2001
    New York
    just did, installed it, and it popped up the same error message, "the latest directx runtime is not installed!"
    come on..how can i not have it installed.. 5 years and now i see this message. baloone. i know its installed, else i woudn't have been able to do anything (what i do to this day) on this pc. anyway.
  7. DECEASED
    Jun 2009
    Heaven
    Do you have 7-zip 9.20 ?????
    I have right-clicked the damn "directx_Jun2010_redist.exe", and 7-Zip shows
    1 zillion cab files, 2 DLLs and 1 EXE.
  8. Member vhelp's Avatar
    Mar 2001
    New York
    i have 9.22 beta on home pc. my netbook (behind me) has 9.20, just installed it this afternoon.
  9. Member vhelp's Avatar
    Mar 2001
    New York
    (resolved)
    the suggestion for versions 9.22 and 9.20 did not work.
    however, thanks to fritzi93, mpc-be worked. it only popped the message once, but subsiquent file loads no longer show that message. i will stick with mpc-be since it works well. i guess tomorrow i will know if it truely worked or is something that occurs only once upon initial startup of every fresh bootup. or, maybe it needed to create a special file or register in the registry once. i don't know. anyway. i can live with that if that turns out to be the case. otherwise, i hope it was resolved.
  10. DECEASED
    Jun 2009
    Heaven
    OK, you'll use MPC-BE, but I'd like to explain why 7-Zip didn't work for you ---
    --- the installer you downloaded today is different from the installer I downloaded 3 years ago
    This new type of compression (still) fools even the Universal Extractor, which then will call the 7z DLL and will show the same garbage as 7-zip
  11. Well, I hope that's the end of those error messages. Too bad the fix didn't work, though.
    Pull! Bang! Darn!
  12. So has 7zip compression changed a bit over time? I wondered why my old version of WinRAR wouldn't extract the odd 7zip file and I've had to download 7zip.
    Speaking of which..... and sorry to wonder off topic a little.... what am I missing when it comes to 7zip? After installing it and compressed several folders containing various files into a 7zip file, I then repeated the process using WinRAR to compress to both RAR and ZIP.
    7zip failed to produce a single archive which wasn't a little larger than both the RAR and ZIP versions.
  13. Member vhelp's Avatar
    Mar 2001
    New York
    ot is fine by me.
    yes, confirmed..it worked out..no error message. it only comes up when i open *any* video files in mpc-hc.
    mpc-be is working out well. but as i vaguely mentioned earlier, i am also working on a basic player of my own through dspack for delphi. but i wish i had some nicer looking UI controls and not the older boring ones that come with delphi. i did purchase the nextgrid suite a couple of years ago, the grid is ok and comes with a couple of nicer controls but not much i can do to polish up my gui's a little better. if i could find some good quality controls i'd buy them. oh well.
