I have like 2000 wmv files on my HDD and I can open and play them all. Using the Windows codecs and FFDshow too (FFDshow ffdshow_rev4043 20111118 - IIRC latest for Win2k SP4).
However recently I encountered two WMV files, that are of high resolution and cannot be opened.
They just won't start playing. If this is because they are so CPU hungry, then I tried to open them in VirtualDub. I like the fccHandler WMV plugin a LOT ( http://gral.y0.pl/~fcchandler/ ). With the latest v2.8 it seems to be absolutely flawless and open all the WMV files I ever encounter... untill now.
Some suxxka produced a 1920x1080 WMV files that this plugin cannot handle at all. The fact that I cannot even play them (and that the sample is very likely a p0rn or some weird kinky sort) is IMHO not a reason for not being able to actually open the file, right?
Plugins should not have a "taste" and open only more interesting stuff.
However there are the sample video (273MB, did not find anything smaller, another example is 300MB...) that cannot be opened, much less played by VirtualDub with the WMV v2.8 fccHandler plugin. Anyone can tell me why and is this fixable? Ulozto.cz show preview of this file w/o a glitch... so the file itself should be video and should be playable / possible to open in VirtuaDub. But upon opening it show just a green video screen with nothing on it. Not cool. BSplayer looks that it is playing, but show only empty screen. Same MediaPlayer Classic. Help?
http://dfiles.eu/files/sasby8i3p
http://ulozto.cz/xhLci92b/not-possible-to-open-vid-wmv
http://fastshare.cz/2240081/not-possible-to-open-vid.wmv
http://www.sendspace.com/file/ge5ce4
Thanks.
	"I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config
	Have you tried opening the videos in Windows Media Player? VLC?
 Are you sure the WMVs aren't DRM-protected? You might take them to a different system, and see if they play.If cameras add ten pounds, why would people want to eat them?
	That might be drm as ai haibara has suggested.Originally Posted by trodas
 mpchc or vlc should play virtually any file.
 The other possibility might be that the file is corrupted somehow. If possible get another copy of the file and try again.
 And in the future to open just about any video file in virtualdub use the directshowsource option in the open file dialog box. Then it creates a 1kb avs script file and automatically loads the flie into virtualdub. That is assuming its not corrupted and its not drm'd.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	Never using Windows Media Player, yet VLC - but I manged it to play using the very same FFDshow settings AND drivers on WinXP. Main machine is Win2k SP4...
 So not need to futher test these ideas (corrupted, DRM protected), because the file works. But not on W2k SP4 system. So Windows 2000 have some video size limitation that prevent them opening a 1920x1080 sized vid? And why VirtualDub also failed?
 Ah, disabling the support in FFDshow for the VC-1 (WVC1, WMVA) make the video playing. But still that did not help VirtualDub to open it and show it... damn.
 Also on Win Vista (Win Media Player 11) it works just fine and playing (tough the clip itself it not probably worth it), yet there we have the problem with VirtualDub now...  Last edited by trodas; 10th Aug 2013 at 10:23. "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config
	@trodas - regarding virtualdub - have you tried the directshowsource technique I mentioned?
 And just out of curiosity why are you still using windows 2000?
 And have you tried mpchc on windows 2000? You did not mention trying that program on that computer.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	About VirtualDub - yes, directshow works. Also probably will work the ffmpeg plugin... I was just too used to the wmv plugin from fccHandler works fine, that I never imagined it could fail me so badly...
 W2k because in WinXP I can't stand being unable to set even the default view for the open/save dialog. I wanted by default it open LIST of files, and it always open THUMBNAILS:
 ...and no-one can even tell me how could I change that (including hacking the DLL, I can do it, but this is a *MUST*) ...
 About mediaplayer - I use version that last support the *.bik decoder library, later versions does not support it, so I stick with this old one. It is irellevant now, as the "not playing" problem are traced to FFDshow settings and failure to play the vid."I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config
  WebEx WMV file, can't open in VirtualDub, says "missing codec"By violetta in forum Newbie / General discussionsReplies: 13Last Post: 22nd Jul 2016, 22:39
  How to open MP4,MKV,WMV,RM,MOV,OGM with any editor,encoderBy Baldrick in forum User guidesReplies: 78Last Post: 24th Feb 2011, 10:53
  burning a dvd from an .avi file and a .wmv fileBy marlo in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2010, 07:06
  cant open wmv files. have read previous forums.By UmmAddan in forum Newbie / General discussionsReplies: 9Last Post: 29th Dec 2009, 13:49
  Possible to get VirtualDub to open wmv/flv files without ffdshow?By tigerb in forum Newbie / General discussionsReplies: 5Last Post: 20th Nov 2008, 21:09
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
