I've got about 60 miniDV tapes and my camera won't play them, it winds the tape in, unwinds it and ejects them.
I'm guessing my options are;
1. fix the camera
2. buy another miniDV camera
3. rent or buy a miniDV deck
4. hand the tapes over to a conversion service
Live in Sydney Australia
As the tapes are getting old, its time to get the them onto the PC
Views, opinions, suggestions? Appreciate your input
Results 1 to 16 of 16
Have a nice Day
Minimum cost: Buy a used miniDV camera from eBay or somewhere. They cost next to nothing.
If your tapes were recorded in LP mode, you may have trouble getting them to play on another camcorder. If this is a problem, getting your original camcorder fixed may be your only option.
Minimum hassle: pay someone else to do it. Though it'll be hassle if they don't know what they're doing, or make a mess of it.
Cheers,
David. -
Of course, the repair shop will probably reset everything to factory settings, in which case older LP tapes probably won't play, anyway.
If they're SP a cheap camcorder from e-bay should handle them. Or ask around -- maybe a friend still has an old camcorder that they'd let you borrow.
Steve -
??? What does it have to do?...LP mode IS part of the "factory settings"..isnīt it?..You just select using SP or LPOf course, the repair shop will probably reset everything to factory settings, in which case older LP tapes probably won't play, anyway.
The problem as I understand it is that the heads sometimes will get slightly out of alignment. In SP mode there is enough tolerance that the heads almost never get far enough out of alignment that they can't read an SP tape. LP mode has much less tolerance. Thus it's more likely that an LP tape recorded with the heads slightly out of alignment can only be played back successfully if the heads are almost exactly the same amount out of alignment. That's why trying to play an LP tape on a different camcorder is problematic.The repair shop would almost certainly put the heads back to the initial factory setting, which may or may not be where they were when a specific tape was recorded.
Or at least that's what I've been told. -
Some of them are in LP. I could ask the repairer not to reset it, appears to be a mechanical issue with loading the tape.
Spotted another Hurdle, my laptop doesn't have a 1394 port. I've got an old desktop that isn't working, could get fixed, shouldn't cost too much.
What's the story with paying someone to do it? Will they give me the raw data or something like mpeg2 ?Have a nice Day -
Had a similar problem with my Sony miniDV camcorder. Hadn't used it in quite a long time, and when I went to load a tape, mine did basically what you describe yours doing. Turned out it was just the tapes. I manually wound both tapes forward (they were at the beginning of the tape) using a large flat-head screwdriver on the front reel for 10-20 rotations, and then tried them again in the camera, and it didn't spit them out. Fast-forwarded them both to the end and then rewound them again to retension them and now everything works OK. Given you mentioned the tapes were old, this might be the issue. Might be worth a shot to try before bringing your camera into the shop, etc.
What Steve Stepoway said.
However, LP tapes can play just fine on other camcorders. There's just no guarantee that they will.
e.g. My Sony DV camcorder must have had serious mechanical/alignment problems. Some of the first and last SP tapes I recorded don't play on anything else. Even so, many of the LP tapes I recorded in the middle years (when it seemed to be behaving itself!) play fine on almost anything. Of course the LP tapes from the early years are even more hopeless than the SP ones.
Cheers,
David. -
I am in a similar situation as you are. I have many minidvs tapes however my cameras works totally fine but sadly i cannot connect it to my computer as i dont have stupid firewire port because i want to transfer these tapes to digital. I am thinking of buying a dvd recorder. Something like this: http://www.bestbuy.ca/en-CA/product/toshiba-toshiba-1080p-upconverting-dvd-recorder-dr...rchPageIndex=1
Or, for a hell of a lot cheaper: (As examples)
http://www.newegg.com/Product/Product.aspx?Item=N82E16815287004
http://www.newegg.com/Product/Product.aspx?Item=N82E16839158040
(And you probably should have started a new thread.) -
I'm not so keen on transferring to DVD as I intend to cleanup and edit in the future, so I'd prefer to have the native data.
Have a nice Day -
According to the discussion here: http://www.computerhope.com/forum/index.php/topic,139421.0.html. I dont think my laptop has the express slot.
I have the regular memory card slot for sd cards is it same as express slot?Last edited by kaboose786; 14th Aug 2013 at 00:35.
To clarify there is the DVD video standard and there's the disk, which holds 4.77GB when single layered and single sided.
Off memory 45min of minDV is about 14Gb (someone can correct me on that). So if it was transferred to DVD as data, then you would get something like 15 minutes per DVD.
I would say they are almost certainly converting the data to MPEG2 DVD compatible format, which involves re-compression of the video. How much quality lost occurs is debatable, but it does occur.Have a nice Day -
My advice (feel free to ignore it
): buy a cheap used desktop and install a cheap firewire card. Install (internally) the new large HDD you want to capture to. If it's SATA, you may also need a SATA card to use it in an old PC. Sell the lot (except the HDD!) when you've finished.
Cheers,
David.
Convert all MiniDV tapes to computer and say good bye to those tapes
By iho in forum Video ConversionReplies: 38Last Post: 17th Dec 2013, 01:01 -
I need to transfer my miniDV and old hi8 tapes tapes to dvd
By bryanport in forum DVD & Blu-ray RecordersReplies: 9Last Post: 21st Dec 2012, 20:53 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 19:07 -
can you convert old tapes to dvd? (old camera broke)
By bojadada in forum Newbie / General discussionsReplies: 0Last Post: 23rd May 2009, 22:31 -
convert avi to dvd with ffmpeg doesn't work-why?
By lilly333 in forum ffmpegX general discussionReplies: 21Last Post: 18th Mar 2009, 17:00
