hi all. as some of you may know, i run my os on fumes. i am currently down to 110mb on my root drive. please don't lecture me on the don't's. anyway.
in effort to save what's left on my c:\ drive, i'm trying to extract (and install) the
"MSYS_MinGW-w64_GCC_481_x86-x64_Full.7z"
to a 32gig memory stick that i use to install and run most of my software apps. this has been working fine for me for quite some time. on occation i run into scenarios like this one but had ways around it. for insance, files that are .rar, i can use their special extract feature to extract files to any other hdd w/out it (winrar) ever touching my c:\ drive. however, .7z doesn't seem to have this feature that i know of. if someone knows how i can set .7z to extract "direct" (for lack of proper term) to mem stick, i would greatly appreciate it. thank you.
Tools => options => folder => you can specify the working folder (normally system temp folder on c )
solved
the funtion steps are:
1. right-click the .7z file
2. select the folder in question
3. right-click the folder and select 'copy to..' or F5
4. finished
c:\ drive never touched.
i have this little applet i wrote (delphi) some time ago for win98 when i used to run out of hhd space a lot, it lets me watch whatever drive is in use in real time.
pda, is that for .7z tool ?
or windows.. to redirect temporary file usage elsewhere ?
if for windows, that would be great! because this file is still extracting, its 60% completion, aprox 8 minutes ago, still running. i'm getting worried i won't be able to install it.
never mind..i got it..Last edited by vhelp; 8th Aug 2013 at 19:27.
That's for the temp/working directory, and I assumed you meant the offical 7zip program, but it looks like you are referring to something else
You can also right click and "extract files" as well and specify a directory if you have the context menu option installed
Help converting DVDs to MP4 for ext HDD playback with Samsung TV
By Webup in forum Video ConversionReplies: 16Last Post: 11th Oct 2012, 08:06 -
Studio14 HD Ultimate, can't open project files from ext. HDD!!!
By rivrbyte in forum Newbie / General discussionsReplies: 1Last Post: 9th Jul 2011, 14:49 -
LG DVX 482 H Player and ext. HDD DVD playback
By no-fast in forum DVD RippingReplies: 0Last Post: 11th Mar 2010, 03:33 -
ext hdd works on philips not on pc
By catdaddio6 in forum ComputerReplies: 7Last Post: 23rd Feb 2009, 12:28 -
Problem Formatting Ext HDD Fat32 Partition
By Shaky Jake in forum ComputerReplies: 6Last Post: 3rd Jan 2009, 16:27
