I also noticed when I used the encoder in MeGui that the output files were changed from 29.970 to 59.940 which would explain the slow encode time and the codec ID was FMP4 but the file I changed the settings on to get faster speed was encoded correctly at 29.970 and the codec ID was XVID.
Results 31 to 32 of 32
I give up. As long as I can't get more than 40% CPU usage the encodes will never go much over 50fps. Good luck! Not worth wasting anymore of my time on it since I don't encode to XviD. Like I said, I'd just use the DivX codec in Home Theatre Mode, Constant Quantizer of three. If you want more speed then set it to High Performance. I'm encoding the same 720x480 video that I couldn't get more than 50fps at 90fps with DivX in Virtualdub.
How to speed up video conversion
By csc12345678 in forum Newbie / General discussionsReplies: 20Last Post: 15th Feb 2012, 00:43 -
How do I speed up my video to 10X speed?
By mileena in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2010, 13:24 -
basic questions about xvid conversion speed
By spiritgumm in forum Newbie / General discussionsReplies: 2Last Post: 24th Jun 2010, 18:20 -
Divx 7 conversion failure/speed up
By Vlenbo in forum Video ConversionReplies: 3Last Post: 15th Jan 2009, 16:20 -
What Determines Your Conversion Speed?
By bangincaraudio in forum Video ConversionReplies: 3Last Post: 15th Nov 2008, 02:13
