I have been using dvd slideshow on windows 8 and most of the time when i use audio with the slideshow
the program crashes while its converting the sound. This happens most of time, only on rare occasions
it manages to complete the iso file with the sound
I tried using different slide transitions and same result occurs
the computer configuation is:
windows 8
intel i5 3570
4gb ram
realtek high definition audio
i have about 250 bmp images
the sound is an mp3, set to use video audio and loop
If i dont use any audio with the slideshow for the iso it manages to complete the iso everytime
When i did it on my laptop (windows xp) it works and completes the iso with sound
but takes a lot longer its an old machine and gets hot
the old machines configuration is:
windows xp sp3
intel core 2 duo t8100
2gb ram
sigmatel audio
i tried removing the new.ini file as mentioned in another topic, where someone
had a similar error message but it didnt work
Is there way of doing it on the desktop with sound with out crashing?
Thanks for your help
