Hello,
I wanted to see what the best process is to free up an SD Card. I opened up the drive on my computer, copied and pasted the whole folder called Private to keep the whole AVCHD root structure. Is that the best way to do it and then delete everything from the SD card? I have heard about reformatting the SD card, but not sure if this is necessary. And this may seem like a silly question but can I rename the Private folder? I don't want 100 folders called Private on my HD. Any feedback would be greatly appreciated. Thanks!
You shouldn't need to reformat the SD card. Just delete the files and record new ones. You should be able to name the folder anything you want, unless the recording software/hardware names it automatically. Even so, when you transfer it to your PC, rename it then.
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 12:27 -
Built In Multiple Card Reader Won't Recognize SD Card
By V Bot in forum ComputerReplies: 9Last Post: 7th Oct 2011, 23:01 -
Very Weird issue with Capture Card and Graphics Card? Please help
By Ps3riiper in forum ComputerReplies: 9Last Post: 11th May 2011, 15:51 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 16:13 -
Reusing miniDV tapes
By yurkyurk in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 27th Oct 2008, 15:06
