I decided to back up my glee dvd discs and found that after running the videos through handbrake and choosing the vobsubs as the main subtitles that after the mkv are authored and burned to blu-ray that some of the subs didn't show up.
After a lot of muxing and testing i found that if the sup starts with no dialog(empty) in line one that the subtitles will not show up.What i did is ran the sup through BDSup2Sub and excluded the first frame of the subs with no dialog and saved then the subs would show up.
With multiAVCHD 4.1 if you are adding the videos with the new sup then you have to add as an external sub or it will no show up if its muxed into a mkv.
Results 1 to 1 of 1
How to extract subtitles from a Blu-ray and convert to srt or sub/idx
By Baldrick in forum User guidesReplies: 35Last Post: 6th Dec 2021, 08:00 -
Blu Ray LG HR-550S - not showing any picture (pls help)
By rodarkone in forum DVD & Blu-ray PlayersReplies: 0Last Post: 2nd Jun 2013, 12:28 -
External Blu Ray not showing up on devices
By parmo in forum DVD & Blu-ray WritersReplies: 9Last Post: 8th Jan 2013, 12:29 -
SUB/IDX blu ray subtitles are BLINKING.... ?
By siratfus in forum SubtitleReplies: 0Last Post: 11th Jul 2009, 17:25 -
BDSup2Sub - A converter from Blu-Ray SUP to DVD SUB/IDX (VobSub)
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 2nd Mar 2009, 21:46
