Dear All,
I have a philips BDP 2930/98 and it has cinavia protection on it
its firmware is 2.36.
Does anyone know have a firmware of an earlier date without cinavia protection?
or anyway to remove the cinavia on this player?
The only way to remove Cinavia is to downgrade your firmware. I do not know if that is even possible on your player. On some players it is not possible.
I'd like to point out that legally purchased discs with Cinavia will play fine so it's not like you have no way to deal with this situation, but I suppose you're not going to like me pointing that out.
Geez, are you trying to set a record between when you joined and when you made your first post? -
thanks jman
hahahah! yeah its been awhile. this forum has always been really useful and have always answered my questions! so there was no need for me to even post. haha.
on your comments thanks a lot. yeah i was hoping for some older firmware i could try to downgrade but i guess there is none?
will just have to buy another one withouth cinavia.
i will use this for my dvds i guess
imagine this....RM(malaysian ringgit) 70 for an original blu ray compared to a cheap 18 for a pirated one.
thanks a bunch -
I truly have no idea if older firmware exists, where you could find it if it does, or if your player will even let you install older firmware (some absolutely will not allow this). Maybe someone else can respond on that.
also, trying to downgrade the firmware can leave you with a bricked player
Philips BDP 2700/05 - region code hack???
By MAC-IRELAND in forum DVD & Blu-ray PlayersReplies: 24Last Post: 30th Nov 2011, 09:00 -
Philips BDP 3000 - Region Code Help
By zzdiwan in forum DVD & Blu-ray PlayersReplies: 5Last Post: 8th Oct 2011, 08:49 -
Philips BDP 3010
By delphy in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Sep 2010, 01:03 -
Philips BDP-7300 MKV support?
By bagmand22 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 10th May 2010, 03:28 -
Philips BDP 7310
By leonidi1972 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 7th Dec 2009, 08:04
