I've been using Final Cut Pro X to create some video clips
The first video plays and has a title, it loops once
Then this video is made less than 25% the screen size
Below it, there is 4 further videos - each less than 12.5% of the original
On the right hand side there is text
I've created 70+ videos of the above, all the same, except the first video - which is different
Is there anyway of automating this?
I've asked in Final Cut forums and the answer is I can't
Just wanted to know if there was anything else
I can only work on my Mac - my PC laptop, if I could use, would take forever to process
OM
Please post in the mac forum if you only can work on your mac. I'm moving you.
Nope, I have no idea how to make a batch for this.
Any advice on how to split a large AVI into smaller clips easily?
By Bluelude1 in forum Capturing and VCRReplies: 11Last Post: 19th Jun 2011, 12:55 -
Automating encoding - publishing process
By fiyahd in forum Video Streaming DownloadingReplies: 8Last Post: 14th May 2010, 17:09 -
Automating MKV Conversion
By perros in forum MacReplies: 0Last Post: 14th Nov 2009, 04:06 -
Automating transcoding and uploading jobs
By justeagle in forum Newbie / General discussionsReplies: 4Last Post: 3rd Sep 2009, 06:46 -
Need advice on batch editing a large number of clips
By clarkkent in forum EditingReplies: 6Last Post: 6th Apr 2009, 16:57
