I followed all the steps from
https://forum.videohelp.com/threads/270926-How-to-convert-jpg-pics-to-avi
and
http://www.virtualdub.org/blog/pivot/entry.php?id=34
but the jpgs still are NOT loading!
I checked the Automatically load linked segments
I set the File type to Image Sequence
What did I do wrong?
It's about 27.000 jpgs
				Results 1 to 12 of 12
	Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
	what version of vdub are you using ?
 are the jpg's sequentially numbered? eg. 000001.jpg, 000002.jpg....
 try a test with just 3-4 jpgs in a folder ( it might be vdub slow loading thousands of jpegs) , to rule out image importing issues
 alternatively you can use ImageSource() if you are familar with avisynth
	are you images are named with sequential numbering?
 (poisondeathray was faster ) )
	should i be insulted? no.  j/k j/k
 But, yes of course the images are sequentially numbered. Stupid of me not to mention that first. Stupid of me not to mention that first.
 I use virtualdub version 1.9.11
 I've tried it with 100, 50 and 6 images, no joy whatsoever.
 What is ImageSource() and how do I use it?
 I've tried VirtualdubMod 1.5.10 too, don't work.Last edited by KneeRow; 5th Aug 2013 at 11:51. Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
	hmmm, did you see the two people asking this same question? Yes? And me answering this?
 Then have at it:
 to be clear, these are Vdub generated images, from an MP4 file, yes I have the mp4 addon/filter.Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
	I Just did the following:
 1. copied a bunch of jpgs inside a folder
 2. renamed them so that they match your naming
 3. opened Virtual Dub (1.10.3)
 4. drag&dropped the first image into Virtual Dub
 -> all files were displayed properly
 Can you open the files in a normal image viewer?
	I am SOOOOOOOOOOOOOO ashamed! It WAS the image sequencing! You can see in the above list, every fourth file is missing!!!!!
 SHAME! SHAME! SHAME! SHAME! SHAME!
 ("BANGS head against granite keyboard!")
 I am sorry to have wasted your time.
 I wanted to make the video a slow-motion video via this method.
 But I changed my mind and wanted to slow it down with a factor THREE, not FOUR, which of course broke the sequence.
 [2] I extracted all frames as pics with Virtualdub, about 1600 pics in total.
 [3] I then copied this four times, until i had 27600 pics, four sets of 6800 pics.
 [4] I then renumbered them with Total Commander, from 1a, 1b, 1c, to 1, 2, 3, 4, ....27600.
 [5]I then loaded them back into Virtualdub,
 This is prolly not the best way to get a slomo video, but it's cheap, and entirely my own. so ...  Last edited by KneeRow; 5th Aug 2013 at 12:23. Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
	you could have just changed the output frame rate or use a decimate-filter for Virtual Dub
	You can do slomo in avisynth, but it can be difficult to learn at first
 A free program that allows for ramping (curves) with a GUI featuring smooth transitions is slomovideo
 http://slowmovideo.granjow.net/
 It allows for optical flow (motion vector interpolated frames) , not just simple inserted duplicates or inserted blended frames - it's a alternative to more expensive plugins and programs like twixtor, after effects ,nuke
	thanks, you two, i will give it a shot. Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
	What was all the fuzz about?
 http://youtu.be/fZuXJwcLdSILast edited by KneeRow; 5th Aug 2013 at 15:13. Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
  Video Container Changer don't work! Help!By Stears555 in forum Video ConversionReplies: 1Last Post: 11th Mar 2013, 03:33
  CUDA don't work, why?By lovelylisa in forum Video ConversionReplies: 38Last Post: 24th Jun 2011, 17:19
  BD Sup to srt and why they don't work all that weLL.By cal_tony in forum SubtitleReplies: 2Last Post: 4th May 2011, 10:17
  Sequencing my DV from Analog to AVI to iMovie. Format? Compression?By kiararden in forum Video ConversionReplies: 4Last Post: 2nd Oct 2009, 11:20
  Printed page image don't equal PC monitor's image?By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 11th Nov 2008, 14:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
