I've been picking up more anime blurays and I noticed two interesting features:
1080i video
and
dts ma 2.0 audio
Of course these are store bought blurays but I'm wondering why any studio would produce a 1080i disc. It must obviously be part of the spec for it to be a pressed factory bluray but I guess I wonder why. If they are already at 1080i why not just do the 1080p transfer?
Also regarding dts ma 2.0 - isn't it overkill to do stereo in dts-ma? I guess technically to me dolby truehd in 2.0 would be overkill since both are lossless.
Maybe I just expect stereo only sources to be lossless pcm. So I guess technically its no different if its in a dtsma or truehd form then is that correct? I mean given the same bitrate and source are all three lossless codecs virtually identical? I mean in the bluray world?
Would a soundtrack - 5.1 or 2.0 - in lossless pcm, dtsma or truehd be truly identical in the real lossless world?
Is there any filesize gains to be had at the lossless level? Or is lossless identical across the formats?
Is it a licensing arrangement that determines the codec used? Is lossless pcm a truly "free" codec for a studio to use? Is dtsma the most expensive?
If so why wouldn't a studio pick lossless pcm 9 times out of 10?
Or is it more a marketing gimmick to have the dts name on it for the audio snobs who think dts is the end all and be all of digital audio?
Thanks.
There exists a *filesize difference* between a 2.0 DTS-MA stream and a 2.0 PCM stream,Is there any filesize gains to be had at the lossless level?
guess which one is less huge
Also, there exists a filesize difference between a DTS-MA encode and a TrueHD encode from the same source.
DTS-MA compresses worse than TrueHD, because the lossy core uses CBR, which is less efficient than VBR (whereas TrueHD has no lossy core to depend upon, even though an "interleaved" AC3 substream is mandatory for Blu-Ray audio). Technically the DCA compression supports VBR, but no encoders available thus far have implemented it, plus, the DVD-Video specs and the Blu-Ray specs do not support it either. Besides, there exists *pure* DTS-MA (i.e., without a DCA core), but again, this is not defined in the Blu-Ray specs.
Depends of course on what you mean by "identical"Or is lossless identical across the formats?
That's it, you're expecting too muchMaybe I just expect stereo only sources to be lossless pcm.
No, it's less expensive (and less of a P.I.T.A as well) than TrueHD:Is dtsma the most expensive?
https://forum.videohelp.com/threads/342599-What-happended-to-Dolby-TrueHD?p=2250448&vie...=1#post2250448
>> 1080i vs 1080p <--- I leave this to someone else like poisondeathray or jagabo
You cannot have 30fps progressive in 1080 resolution on Blu-Ray,
test if it is fake interlace, load it into MPC-HC for example with no interlace filter and manually step frame by frame
it is quite weird now, you cannot author BD with 30p but there are exceptions now for 60p, well players might play those 30p or 60p anyway but no BD authoring , https://en.wikipedia.org/wiki/Blu-ray_Disc#Video -
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
@ el heggunte - thanks for the info. I would not have expected dtsma to be cheaper or easier to work with.
@ _al_ and turk690 - I don't have the bluray on me at the moment to do media info on the m2ts files. That should give me everything I need to know.
Actually this is nothing I"m doing - I don't even have a bluray burner, rom only. It's a pressed factory disc I"m referring to that says its 1080i video.Originally Posted by turk690Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Seen alot of documentaries ie wonders of the universe with two ch lossless
if all else fails read the manual
copy original dts master audio from blurays
By fireblade458 in forum Blu-ray RippingReplies: 8Last Post: 18th Jan 2013, 11:34 -
Converting 1080i 30fps to 1080i 25fps
By Bencuri in forum Video ConversionReplies: 0Last Post: 21st May 2012, 09:05 -
BluRays not playing right on N1
By x22 in forum Blu-ray RippingReplies: 4Last Post: 16th Oct 2011, 15:43 -
What do you use to play Blurays?
By Dexx in forum Software PlayingReplies: 9Last Post: 24th Jan 2011, 17:27 -
Camcorder: buy 1080i or 1080p? Final Cut Express only does 1080i
By adrien23 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 12th Nov 2010, 06:37
