Hi Gays Thes amazing settings encoding Tv
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 35mn 30s
Bit rate : 2 100 Kbps
Width : 1 280 pixels
Height : 672 pixels
Display aspect ratio : 1.905
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.098
Stream size : 521 MiB (90%)
Writing library : x264 core 133 r2334 a3ac64b
Encoding settings : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=2100 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=50000 / vbv_bufsize=50000 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Image From Video
I want to know how the operation of these settings in program staxrip or megui
please help me gays
here are the non-default settings from these infos:
using these and http://mewiki.project357.com/wiki/X264_Settings it should be possible to adjust MeGUI the way you want toCode:--bitrate 2100 --profile high --level 4.1 --ref 4 --min-keyint 25 --direct auto --b-adapt 2 --qpmin 10 --qpmax 51 --me umh --subme 6 --trellis 2 --vbv-maxrate 50000 --vbv-bufsize 50000 --cqm jvt --deblock -1:-1
(Sorry, can't help further, since I don't use MeGui or StaxRip) -
Welcome. Are you playing with MeGUI and StaxRip to figure out best settings or with forum members? The images you posted are processed under different settings or different filters, and both are on ugly extreme. Did you notice anything just by looking at? I can not comment much as I do not use MeGUI, RipBot or StaxRip.
this my friend Settings in video I do not know what program is used and what Filter
I,m used staxrip and megui Always
Based on your experience pleasant in encoding What is the program used to my friend, who gives such settings ??
My friend also converts from ts or Mpge to Mkv . -
I am also a newbie like you, for me there is an ocean to dive-in to search a pearl. The experience in encoding was not that pleasant at all, someone really offered helping hand and someone liked to kick my ssa. But, now it is pleasant any way no matter which way it goes, i guess. Just, Let it go!Based on your experience pleasant in encoding.
I wish if I can. If I say some settings likePlease help me
x264 core 133 r2334 a3ac64b.exe --input somefile --bitrate xyz --settings extraordinary --quality superb --artifacts zero
I am just bluffing bcoz I really know nothing about how these settings work. I wish I can jump over that barrier too, one day.
MeGUI, StaxRiP, RiPBot, HcEnc and some other tools already banged BiG Ben's theory, The only matter is I am not yet exposed. In spite they banged higher heights they had fallen short, too shart for a reason or two.
May be someone who uses same tools may over take, and they will definitely help you out with some better settings, some better explanation, some better suggestion etc.
Meanwhile, I would just suggest Look Here try and tweak 720p setting. see what settings give you desired result.Last edited by enim; 5th Aug 2013 at 16:26.
Rate Control Settings for new Staxrip...
By The.King in forum Video ConversionReplies: 155Last Post: 9th Jan 2013, 13:57 -
Aspect ratio slightly off? (Megui, Staxrip vs Xvid4PSP)
By ARTO65 in forum DVD RippingReplies: 24Last Post: 15th Jun 2011, 10:32 -
Need Help With StaxRip Settings For Exact Quality?
By skorpinok in forum Video ConversionReplies: 1Last Post: 29th Aug 2010, 12:36 -
Best settings for VHS Rips useing STAXRIP
By contactadam2002 in forum Video ConversionReplies: 3Last Post: 25th Jun 2009, 18:33 -
Which is the best encoder? FFmpeg? staxrip, or megui?
By Vlenbo in forum Video ConversionReplies: 7Last Post: 15th Dec 2008, 00:08
