When I burn this movie to DVD using DVDStyler I get choppy video. I don't know why this is happening because it is 23.976 fps.
I'm guessing it's because it's M=3, N=18 when it should be M=3, N=12.Code:General Complete name : bb.mpg Format : MPEG-PS File size : 2.09 GiB Duration : 2h 20mn Overall bit rate : 2 137 Kbps Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : Yes Format settings, Matrix : Default Format settings, GOP : M=3, N=18 Duration : 2h 20mn Bit rate mode : Variable Bit rate : 1 711 Kbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.206 Stream size : 1.67 GiB (80%) Audio ID : 189 (0xBD)-128 (0x80) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Muxing mode : DVD-Video Duration : 2h 20mn Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -8ms Stream size : 385 MiB (18%) Menu
I used Avidemux to convert an .mkv to .m2v. If I go to Avidemux and change the Gop Size from 18 to 12 will that fix it?
NTSC dvd video should be 29.97 fps. Somewhere or other,
there should be a 23.976 > 29.97 pulldown step. -
Right, and because it's not DVD compliant I suspect DVDStyler reencodes. It has to as it will never author in the state it's in. Maybe the jerkiness resulted from the reencode (perhaps it added a duplicate frame in every 5).
No. Although it'll never author with the original GOP settings (and they have to be changed), it'll be reencoded anyway (unless DVDStyler can be told to just to apply 3:2 pulldown, which I doubt). Never used it myself, and any video to be authored should be DVD compliant already.If I go to Avidemux and change the Gop Size from 18 to 12 will that fix it? -
I encode it myself using Avidemux because HCgui didn't want to do it and I only do it like that because if I let DVDStyler encode it it'll make it bad quality. :/ The weirdest thing of all is HCgui didn't want to so maybe it's something with the original file that it doesn't like. I have no idea. I use FitCD with HCgui normally and have no problem but when that doesn't work and I do it with Avidemux putting the filters FitCD has it comes out choppy when burned.
Code:General Unique ID : 210574242727084249082068282965420999785 (0x9E6B1FBBBE1F7B62AD2A0FEC1DC90469) Complete name : bb.mkv Format : Matroska File size : 5.20 GiB Duration : 2h 20mn Overall bit rate : 5 318 Kbps Movie name : BB Encoded date : UTC 2012-07-16 13:58:42 Writing application : mkvmerge v5.7.0 ('The Whirlwind') built on Jul 8 2012 20:08:51 Writing library : libebml v1.2.3 + libmatroska v1.3.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 6 frames Format settings, GOP : M=4, N=42 Codec ID : V_MPEG4/ISO/AVC Duration : 2h 20mn Bit rate : 4 562 Kbps Width : 1 280 pixels Height : 528 pixels Display aspect ratio : 2.40:1 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.282 Stream size : 4.36 GiB (84%) Title : BB Writing library : x264 core 125 r2200 999b753 Encoding settings : cabac=1 / ref=6 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4562 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00 Language : English Audio ID : 2 Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 2h 20mn Bit rate mode : Constant Bit rate : 755 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossy Stream size : 756 MiB (14%) Title : BB Language : English Menu 00:00:00.000 : en:00:00:00.000 00:05:00.000 : en:00:05:00.000 00:10:00.000 : en:00:10:00.000 00:15:00.000 : en:00:15:00.000 00:20:00.000 : en:00:20:00.000 00:25:00.000 : en:00:25:00.000 00:30:00.000 : en:00:30:00.000 00:35:00.000 : en:00:35:00.000 00:40:00.000 : en:00:40:00.000 00:45:00.000 : en:00:45:00.000 00:50:00.000 : en:00:50:00.000 00:55:00.000 : en:00:55:00.000 01:00:00.000 : en:01:00:00.000 01:05:00.000 : en:01:05:00.000 01:10:00.000 : en:01:10:00.000 01:15:00.000 : en:01:15:00.000 01:20:00.000 : en:01:20:00.000 01:25:00.000 : en:01:25:00.000 01:30:00.000 : en:01:30:00.000 01:35:00.000 : en:01:35:00.000 01:40:00.000 : en:01:40:00.000 01:45:00.000 : en:01:45:00.000 01:50:00.000 : en:01:50:00.000 01:55:00.000 : en:01:55:00.000 02:00:00.000 : en:02:00:00.000 02:05:00.000 : en:02:05:00.000 02:10:00.000 : en:02:10:00.000 02:15:00.000 : en:02:15:00.000 -
What's the script you're using? Short before and after samples, 10 second ones with steady movement, might be helpful too. Particularly, the AviDemux result should pinpoint the problem.
Doesn't HCEnc give you an error message? What is it?
You're not intending to stick a big DTS audio track into a DVD5, are you? Shouldn't you convert it to AC3 and extract it for muxing later? -
23.976 fps is ok as long as 3:2 pull-down has been applied in the encoding process. I really do not know if avidemux can do this but I would have thought that Henc can.
But I think your real problem, along with the above, is the bitrate of the video. 1711 kbps is simply too low. You said that Henc was giving poor quality but even discounting the jerkiness you surely can not say that the picture currently looks great. -
Yes, HCEnc will encode at progressive 23.976fps and apply pulldown. I suspect the jerkiness is from AviDemux inserting a duplicate frame after every 4 frames to output the required 29.97fps and that would easily account for the jerkiness. That's why I asked for samples. I don't use AviDemux for anything and have no idea how it encodes for DVD.
MultiAVCHD - choppy video
By bobo343 in forum Authoring (Blu-ray)Replies: 8Last Post: 27th Sep 2010, 18:04 -
How to fix choppy video
By dexter30 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2010, 08:52 -
choppy video on blip.tv
By gtmb in forum Video Streaming DownloadingReplies: 3Last Post: 25th Sep 2009, 10:46 -
After conversion video is choppy
By 2112Video in forum Authoring (DVD)Replies: 1Last Post: 26th Aug 2009, 10:57 -
VOB2MPG choppy video
By 123fish123 in forum Newbie / General discussionsReplies: 4Last Post: 20th Mar 2009, 13:06
