    Sep 2007
    somewhere in videohelp
    hi, i use TmpgEnc 4 to open mp4 files, but it won't work, i have install ffdshow, do i need another codec ? , from mediainfo it says:
    Video
    Format : AVC
    Format profile : Main@L3.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Codec ID : avc1
    Duration : 1mn 30s
    Bit rate mode : Constant
    Bit rate : 506 Kbps
    Width : 640 pixels
    Height : 360 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 23.976 fps
    Minimum frame rate : 23.974 fps
    Maximum frame rate : 2 195.122 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.092
    Stream size : 5.45 MiB (99%)
    Mar 2008
    Perhaps try enabling the directshow import filter within Tmpgenc.
    You may have to also install Haali media splitter.
    https://www.videohelp.com/download/MatroskaSplitter23062013.exe
  3. There are several Tmpgenc products version 4 and above, they are generally quite good at opening files without external codecs. Please be more specific about Which one you are using, and what you are trying to accomplish.
    Your video has an extremely low bitrate (which shouldn't be causing this problem.) Looks like it's VBR which can be troublesome. Is there really no audio?
    Sep 2007
    - i already have Haali media splitter.
    - tmpgenc 4.7.7.307
    - i try to make it to avi or mpg
    - it should have audio, but don't know it didn't show in mediainfo, i get it from here
    http://www.youtube.com/watch?v=V0zTbkySv_o
  5. Try downloading again. Looks like they replaced the file with a CBR one.
    BTW,
    The latest version of your product is 4.7.9.311, released more than two years ago, yours is more than three years old. It was superceded by Video Mastering Works 5. Updating might help.
    The reason I asked for specifics:
    From Wikipedia: "TMPGEnc" is now used as a general brand name for products such as...TMPGEnc Video Mastering Works, TMPGEnc Authoring Works, TMPGEnc MovieStyle, TMPGEnc MPEG Editor, TMPGEnc Instant Show Presenter, and TMPGEnc KARMA."
    Sep 2007
    have tried redownload, but still the same
