I have been using ripbot 264 for years now, never had a problem till now. I have always done my videos in 5.1 @ 320. The last group of videos I have done where all encoded in 2.0
I have gone and deleted all temp files and related to ripbot. Re download ripbot. I went and did 2 test video, and received the same results. I cannot for the life of me figure out what changed. I never changed anything, and made sure with my test videos, that I checked to make the settings where correct.
Any help is appreciated, thank you.
JC
Results 1 to 11 of 11
Ok just to play devils advocate here are you positive this group of videos is actually 5.1?
Also try copy stream and see if that works.
And are you encoding to a mp4 file? I think one version of ripbot I had used would not let me encode to 5.1 in a mp4 file. Switched to mkv and got the 5.1 option. Though that was sometime ago and I don't remember what version of ripbot that was.
As for the batch of videos that are in question use mediainfo to verify each has a 5.1 audio track.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Yes its really in 2.0, I checked.
And yes its MP4, been using the latest release.
I tried the media info and it completely bingified my PC. Even I unchecked the option for it. Had to run ADW cleaner to get it off my pc. -
Nobody has this problem? Or a solution?
I have even reformatted my PC and it still only encodes in 2.0 -
ahh thats why. Yeah I don't have 'KEEP JOBS QUEUE' checked. Next time I do a movie I will check it and post the reults. Thank you for the help.
@JMC907:
I seem to have the problem. Whatever I do, RipBot only encodes 2 channels (using the MP4 container), even though I use a 5.1 audio profile.
You haven't posted anything anymore, so, did you solve the problem? And even more important: How?
Thanks and cheers from Germany
HELP!! Problem installing Ripbot 264
By livluvlife in forum Blu-ray RippingReplies: 11Last Post: 18th Feb 2015, 01:44 -
Ripbot 264 and Commands
By JackDanielZ in forum EditingReplies: 0Last Post: 5th Feb 2013, 10:39 -
RIPBOT 264 - Distributed Encoding 'not shared error'.
By GWOOD in forum Video ConversionReplies: 4Last Post: 14th Nov 2012, 11:14 -
RipBot 264 Speed
By Benjy in forum Video ConversionReplies: 10Last Post: 6th Nov 2009, 01:16 -
Ripbot 264 question
By ultraman36 in forum DVD RippingReplies: 3Last Post: 29th Dec 2008, 12:57
