I'm in need of an inexpensive backlight for a 3 point lighting setup. The setup involves the subject sitting in front of a 70" flat panel television, which makes up the entire background. My thought is to place the backlight on a simple light stand right behind the television screen.
Both the key and secondary lights on the subject are very white color temperature, so I'd like something to match. The backlight will only be a couple of feet from the subject, so I don't want something too strong or otherwise inappropriate for this setup.
Are there some suggestions people could give for the backlight I should use?
What do you mean by "very white color temperature"? for your main lights what do yo use?, tungsten, LEDs, fuorescent?, do you use any kind of temperature control gels?
5600K color temperature. Key and fill lights are fluorescents without temp control gels.
Pros around here would probably consider this:
http://www.bhphotovideo.com/c/product/284755-REG/Lowel_P2_10_Pro_Light_Focus_Flood_Light.html
an inexpensive and simple soluition, and you stillīd have to buy a proper light stand, barndors and proper color color temperature correction gels (not to mention spare light bulbs)
But for something really inexpensive, you could get away with something like this:
http://www.antonline.com/p_Boston-Harbor--TL-CL-170-BLACK33--Boston-Harbor---Flexible-...ck-_816485.htm
You can get some nice lightning tips and ideas from here:
http://www.youtube.com/user/thefrugalfilmmaker
and similar youtube channels -
The film and video/TV industries have used tungsten lighning for many years. Do you mean this?
http://en.wikipedia.org/wiki/UV_radiation#Artificial_sources
maybe I didnīt understand your question.
Anyway, if you go for the Pro light, youīll need a blue color correcting gel to match your other light sources, and a good one will absorb it
http://www.amazon.com/camera-photo/dp/B000B7A30O -
yeah I was referring to this type of thing: http://assets.sylvania.com/assets/documents/faq0015-0297.91f46042-b556-47d4-b5fc-5271137e32e1.pdf
Clear it up: Camera used backlight settings
By co1615 in forum Newbie / General discussionsReplies: 3Last Post: 26th Oct 2010, 06:23 -
Help with unique editing situation.
By BillThomas in forum EditingReplies: 1Last Post: 18th Feb 2010, 13:49 -
Samsung SyncMaster 206BW & backlight bleeding?
By kyrcy in forum ComputerReplies: 0Last Post: 3rd Feb 2010, 11:37 -
LCD Computer Monitors failing (inverter and/or florescent backlight)
By edDV in forum ComputerReplies: 2Last Post: 22nd Aug 2009, 21:36 -
Current Situation re. +R and -R
By nlec in forum MediaReplies: 1Last Post: 23rd Sep 2008, 15:59
