Results 1 to 11 of 11
    Aug 2013
    London
    So I spent ages on editing a video and saved it, but I've gone to open it the next day and it won't work? The file begins to open, but then at 10% it stops and says and error occurred during this current operation? And then it has this as the details...
    Sony Vegas Pro 8.0
    Version 8.0b (Build 217)
    Exception 0xC0000094 (integer divide by zero) IP:0x33A8CF49
    In Module 'mcmp4plug.dll' at Address 0x339A0000 + 0xECF49
    Thread: ProgMan ID=0x14B0 Stack=0x675E000-0x6760000
    Registers:
    EAX=00000000 CS=001b EIP=33a8cf49 EFLGS=00010246
    EBX=0e5c548c SS=0023 ESP=0675ec88 EBP=0e5c53b0
    ECX=00000000 DS=0023 ESI=00000002 FS=003b
    EDX=00000000 ES=0023 EDI=00000000 GS=0000
    Bytes at CS:EIP:
    33A8CF49: F7 F1 8B 44 24 0C F7 F1 ...D: 8B C2 33 D2 4F 79 4E EB ..3.OyN.
    Stack Dump:
    0675EC88: 00000000
    0675EC8C: 0E5C548C 0E2E0000 + 2E548C
    0675EC90: 339B2785 339A0000 + 12785 (mcmp4plug.dll)
    0675EC94: 00000003
    0675EC98: 00000000
    0675EC9C: 00000000
    0675ECA0: 00000000
    0675ECA4: 0E5C5488 0E2E0000 + 2E5488
    0675ECA8: 0E5C548C 0E2E0000 + 2E548C
    0675ECAC: 00000000
    0675ECB0: 00000000
    0675ECB4: 0E5C53B0 0E2E0000 + 2E53B0
    0675ECB8: 0E5C53E0 0E2E0000 + 2E53E0
    0675ECBC: 0675F0E8 06660000 + FF0E8
    0675ECC0: 00000000
    0675ECC4: 00000000
    > 0675ECE0: 77735B0C 776F0000 + 45B0C (ntdll.dll)
    > 0675ECE4: 74FE179C 74FE0000 + 179C (KERNELBASE.dll)
    > 0675ECF0: 74FE17C4 74FE0000 + 17C4 (KERNELBASE.dll)
    > 0675ECF4: 364A9706 36340000 + 169706 (sfmarket2.dll)
    > 0675ED40: 74FFE6FD 74FE0000 + 1E6FD (KERNELBASE.dll)
    > 0675ED4C: 74FE17C4 74FE0000 + 17C4 (KERNELBASE.dll)
    > 0675ED50: 75ACEFA3 75A80000 + 4EFA3 (kernel32.dll)
    > 0675ED5C: 339B2F97 339A0000 + 12F97 (mcmp4plug.dll)
    > 0675ED94: 339B2459 339A0000 + 12459 (mcmp4plug.dll)
    > 0675EE2C: 61766331 61710000 + 56331 (mscorlib.ni.dll)
    > 0675EE38: 00480000 00400000 + 80000 (vegas80.exe)
    > 0675EE3C: 00480000 00400000 + 80000 (vegas80.exe)
    0675EE40: E2556B28
    0675EE44: 404DF853
    0675EE48: 000007FF
    0675EE4C: 00003D96
    > 0675EE50: 007448CC 00400000 + 3448CC (vegas80.exe)
    0675EE54: 000003E9
    0675EE58: 00000001
    0675EE5C: 00000000
    0675EE60: 00000000
    > 0675EEB4: 0055005C 00400000 + 15005C (vegas80.exe)
    > 0675EEB8: 00650073 00400000 + 250073 (vegas80.exe)
    > 0675EEBC: 00730072 00400000 + 330072 (vegas80.exe)
    0675FFF0: 00000000
    0675FFF4: 005258F0 00400000 + 1258F0 (vegas80.exe)
    0675FFF8: 00ADA678 00400000 + 6DA678 (vegas80.exe)
    0675FFFC: 00000000
    I would really appreciate if someone could help me fix it, as I've turned my computer on and off again quite a few times but it's made no difference to opening the Vegas Project.
  2. My best suggestion is to change to another program, sony vegas is SHIT.
  3. Originally Posted by supercain View Post
    sony vegas is SHIT.
    Not in the real world.
    That's a six year old version though (current is 12). Are you running an old enough computer to be completely compatible? Have you sent the error report to Sony?
  4. In any world, that program is buggy as hell... i have 11 but i dont think 12 has gotten that good.
  5. Member DB83's Avatar
    Jul 2007
  6. Version 8.0b (Build 217)
    The crash is in the mainconcept mp4 import plugin. You need to upgrade to 8.0c at least , or preferably something newer.
    There were a lot of bug fixes in 8.0c release, and specifically fixed some MP4 import issues
    Aug 2013
    London
    Ok, so I've updated it, but now it wont open any of my vegas files...and instead just comes up with this:
    The COM object failed to initialize
    ...can anyone help with that?
  8. Updated to what version?
  9. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    wasn't vegas pro 8.1 the last of the 8 series? you might try completely uninstalling 8 and installing 8.1
  10. Yes, there was 8.1 version, but I'm not sure it it was 64bit only. Those 64 bit versions were introduced at that time. 8.0c is 32bit.
  11. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    i went and looked it up. 8.1 could be used for 32 or 64bit os.
    Notable fixes/changes in version 8.1
    • Added support for running under 64-bit editions of Windows Vista™
    • Support for addressing greater than 4 GB RAM for improved memory management..
    • Improved support for multicore processors: Vegas 8.1 can now use more than 4 video rendering threads.
    • You can open Vegas 8.1 projects in Vegas 8.0c and vice-versa.
